View Poll Results: gsr block with ls crank what pistons (low compression)
Voters: 19. You may not vote on this poll
gsr block with ls crank which pistons?
This goes out to the guys running a gsr block with ls crank, I understand that you need to use the ls length rods and I know that the aftermarket b series pistons are all the same except for the valve reliefs for different engines(pin placement is the same). I have gotten mixed answers on this subject in my quest. It would make sense to me that for a high compression build to use the gsr pistons for the extra valve relief clearance but for a low compression build does it matter? should i get the gsr or ls pistons? pistons will be cp.
Re: gsr block with ls crank which pistons?
I would like to know the same answer. More specifically I have a GSR block, LS crank, Eagle LS rods, and I would like some pistons that would net me around 9.5:1 to 10:1 compression for strong off boost power.
Moderator
Well, I guess if I were to go through the trouble of doing this great build, i would not use an OEM piston at all for a boosted setup, whether I had the OEM pistons there or not. that's what the marketplace is for... Otherwise, check your Wiseco,Arias,JE,CP piston catalog for the LS/VTEC hybrid section. (it will say LS block with B16 head, or some similar description.) the compression that they dictate from that setup will be about where you would be if you used an LS crank, LS Rod, B16 or GS-R head
The block that I am building now is a GSR with an LS Crank, I am using GSR Arias Pistons.... would of ran the GSR's if it was a low, mid or high comp setup.
I can tell you that flat top shelf Arias Pistons with a GSR head/block, LS Crank/Rods and a stock size gasket will net you around 10.8:1
In my opinion I would always take a piston that gives me the most P/V clearance that way if you ever swap in a high lift cam and your running OS valves you will have a little more room.
10.8:1 is a wee bit high for boost for my preference, but thanks for the info.
Sorry to the OP, as I don't want to seem like I'm hi-jacking your thread. I'm just interested in the same information you are.
I am running 10.8 because my car will only get E85 or race gas.
i have seen several high compression turbo builds that are very strong..like you said on e85 its very tempting
It can be done on pump too but there is alot of risk involved and little room for error, a bad tank of gas and you could be in for some problems....
Personally a lower compression motor is a more happy motor.. I would stick with something in the 9.0:1 to 9.5:1 range just to be safer. And I also like the choice with CP's not bashing other companies but I personally use CP's and haven't had a problem yet (knock on wood)
http://realstreetperformance.com/store/acura-honda-38/
Real Street Performance..They have rod and piston combos for a great price..alot of reputable brands too! If you email them, they can get you some CP pistons with the LS rods you need for the same price as GSR/GSR combos!
bump for some more opinions...looks like gsr is the way to go for low and high compression
Aftermarket pistons are the sam for gsr or ls the compression will be slightly different but if u order a 9:1 gsr or ls pistons u will get the same piston.
I'm currently running eagle LS rods with ls crank and SRP gsr pistons in a gsr block. its roughly 9.3:1 compression ratio. havent had a single issue and the srp pistons dont expand as much due to higher silicon content so less piston to wall sfor a tigher quieter start up
Moderator
I used a CP piston that was for LS/VTEC at 9.7:1. When you choose from the site, choose as though you were doing an LS/VTEC conversion to get the dome height correct for the compression you want. I never went by "LS" or "GS-R". I went by the specifications of the piston, I guess.
i am running a gsr block and i am using the ls eagle rods, and forged pistons.. you also use all ls acl bearings... main and rod bearings ls.. and thrust washers as well.. that is all you have to know to put the ls crank, pistons and rods in a gsr block.. that is what exactly what i did and it is working fine..
If you use OEM pistons, you're limited to what the LS rods can do, so the higher compression won't harm anything. You won't be running huge power anyways.
