Question: Engine stored more than 3 years, what to do now?
Old Sep 11, 2005 | 09:23 PM
PaChiLa Leader's Avatar
Default Question: Engine stored more than 3 years, what to do now?
Modified by PaChiLa Leader at 4:32 AM 10/10/2005
Old Sep 11, 2005 | 09:51 PM
mmuller's Avatar
Mad Scientist
Default Re: Question: Engine stored more than 3 years, what to do now? (PaChiLa Leader)
i would take the pan out and oil up the bottom end. Then try turning the engine with a torque wrench for results.
Remember that most people that buy swaps; slap it in, put oil in it and crank it up. \
For all you know the engine could of sat for 10-15 years in the junkyard
Old Sep 11, 2005 | 10:08 PM
Default Re: Question: Engine stored more than 3 years, what to do now? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">i would take the pan out and oil up the bottom end. </TD></TR></TABLE>
can you explain this, i am not quite getting it
thanks
Old Sep 12, 2005 | 08:33 AM
mmuller's Avatar
Mad Scientist
turn the motor around on its stand; take the pan out and spray oil all over the rod caps, mains, inside the oil pickup to make priming easier, etc.
Old Sep 12, 2005 | 09:32 AM
Muckman's Avatar
Moderator in Chief
Fill it up with about 10 quarts of oil. Turn the motor over by hand a few times. Then drain all oil and refill with proper amount of new clean oil and filter.
Old Sep 12, 2005 | 11:55 AM
cool~~ it's doable~
so which way should i use? is it more the pain in the *** to take the pan out or spend some extra money to fill the engine oil up? LOL
Old Sep 12, 2005 | 12:46 PM
Muckman's Avatar
Moderator in Chief
I honestly think it would be fine without either method but it sounds like you want to be extra cautious. I'd be more worried about a rats nest in my exhaust. That's gonna stink! lol
Old Sep 12, 2005 | 10:25 PM
Mista Bone's Avatar
D Tranny Guru
install motor, fill with oil, disconnect dizzy/fuel injecvtors, dry crank for 30 seconds......what for the oil light to go off
hook dizzy and injectors back up, fire it up!
Old Sep 12, 2005 | 10:48 PM
Default Re: Question: Engine stored more than 3 years, what to do now? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I honestly think it would be fine without either method but it sounds like you want to be extra cautious. I'd be more worried about a rats nest in my exhaust. That's gonna stink! lol</TD></TR></TABLE>
really? you think i worried too much?
well i just dont' want to have a long *** problems after i installed the motor..
like i would like to figure everything out while the engine is out before i install it..
Old Sep 12, 2005 | 10:49 PM
rev-speed's Avatar
if its a swap
then the tranny and starter is on there
make sure it s full of oil
hook up some jumper cables and jump the starter remote wire to crank the motor(make sure trans in neutral)
Old Sep 12, 2005 | 10:50 PM
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">install motor, fill with oil, disconnect dizzy/fuel injecvtors, dry crank for 30 seconds......what for the oil light to go off
hook dizzy and injectors back up, fire it up!</TD></TR></TABLE>
you mean disconnect the plug that goes to dizzy and fule injectors then turn the ignition to crank it for 30 sec. ?? what do you mean by the oil lights?
Old Sep 12, 2005 | 10:58 PM
Default Re: (rev-speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">if its a swap
hook up some jumper cables and jump the starter remote wire to crank the motor(make sure trans in neutral)</TD></TR></TABLE>
is it better to juse hand crank it? oh by the way, how do i check to see if the gears are in neutral?
sorry guys i have tons of dumb questions hope you guys dont' mind
kevin j
Apr 3, 2014 04:39 PM
illestaznpimp
Apr 27, 2007 09:55 AM
D16y8_619
Sep 8, 2006 09:05 PM
RHDintegXsi
Jun 17, 2006 04:20 AM
Mr.Rab
Jul 6, 2002 04:21 PM
