Tough Tech queston for the tech wizards
Old Jul 5, 2002 | 12:23 PM
Mr.Rab's Avatar
Default Tough Tech queston for the tech wizards
How do you measure 4.2 quarts of motor oil out of a 5 quart jug.
For real need a answer
Old Jul 5, 2002 | 12:27 PM
Spade's Avatar
Default Re: Tough Tech queston for the tech wizards (RAB01GSR)
Estimate what 20% of the bottle is. Or just look on the side and pour in slightly less than 1/4th or 25%
Old Jul 5, 2002 | 01:35 PM
Speed_Ricer99's Avatar
Or you could just guess and keep checking the dip stick.
sure its not the scientific way to do it, but since when did changing oil become a science project.
Old Jul 5, 2002 | 01:38 PM
Spade's Avatar
Default Re: Tough Tech queston for the tech wizards (Speed_Ricer99)
Checking the dip stick will not help......you must check the oil while the engine is hot because that is when the oil is spread through-out the engine and not gathered within the oil pan.
Old Jul 5, 2002 | 01:47 PM
B19CivicHB's Avatar
2 cups per pint.
2 pints per quart...
you need 8\10ths of a quart out of the bottle.
if there are 4 cups per quart... then you need to take out 3 and 1\5th cups. Use a kitchen measuring cup. Easy as pie.
HTH,
-Nick-
Old Jul 5, 2002 | 04:04 PM
riceboy's Avatar
Default Re: Tough Tech queston for the tech wizards (B19CivicHB)
Anyone thught to go to WalMart and buy a transparent bucket with measures on the side??
Old Jul 6, 2002 | 04:21 PM
Default Re: Tough Tech queston for the tech wizards (Spade)
Actually, all honda engines are static type engines which means ALL fluids including
transmission fluid are supposed to be checked w/ the engine off. I don't mean to argue, but I used to work for honda and that was one of their many guidelines on how fluids it should be done.
But I think Riceboy out smarted us both
bopbop93030
May 13, 2008 04:30 PM
Draggin99Si
Jun 15, 2007 09:34 PM
EKcivic1230
May 31, 2005 06:23 PM
todaspecsi
46
Apr 29, 2004 05:08 PM
KCLude01
Oct 13, 2003 01:27 PM
