purging cooling system
Old Dec 19, 2005 | 07:56 AM
fam_mechanic's Avatar
Default purging cooling system
just replaced head,water pump,timing belt,and gaskets.
I can't seem to get the cooling system to bleed all the air out? I just get steam coming from the bleeder valve.Also steam from the overflow tube if i pull it out of the bottle.Also the Fan wont kick on when it get into the red on the gauge.I have about 1.5 gallons of 50/50 antifreeze in it now.The most i get is a couple squirts of green out of the bleeder never a stream of coolant. 93 honda civic with a 1.6,a/c 5 speed
Old Dec 19, 2005 | 09:29 AM
Katman's Avatar
Default Re: purging cooling system (fam_mechanic)
try letting the car idle for about 15min with the rad cap off....keep an eye on the bubbles that arise from the rad filler hole too while its idling.
Also turn your heater on set your climate control to HOT.
mlee19841
Honda Civic (2001 - 2005)
May 1, 2015 03:26 PM
EK9JSPEC
12
Sep 1, 2012 08:51 AM
PeakBoostSi
Jul 7, 2007 03:27 PM
1.8T_EG
Oct 28, 2002 04:17 PM
topher
Feb 2, 2002 06:41 AM
