as well...coolant system problem
Old Jan 30, 2002 | 06:50 PM
topher's Avatar
New User
Default as well...coolant system problem
the engine will come up to operating temp, but no heat will come out of the heater
is it the thermostat? stuck open, stuck closed?
we cant seem to get the motor to take coolant in either?
i dont know how to fill the system
i do th4e following
fill resevoir, open radcap, run with heater on high temp
and nothing happens??
top hose gets warm, not bottom one!
Old Jan 30, 2002 | 06:53 PM
CanadaCivicSIR's Avatar
New User
Default Re: as well...coolant system problem (topher)
Could be your thermostat stuck.
Check it
Old Jan 30, 2002 | 07:18 PM
topher's Avatar
New User
Default Re: as well...coolant system problem (CanadaCivicSIR)
maybe the system is not bled right?
Old Jan 30, 2002 | 07:22 PM
Gasoline Fumes's Avatar
Thermostat won't effect heat.
Old Jan 30, 2002 | 08:00 PM
tinkerbell's Avatar
do you pour coolant into the radiator? or just the resevoir tank?
did you connect the heater hoses to the right bits?
did the heater cable get re-attached to the heater valve?
t..
Old Jan 30, 2002 | 10:52 PM
976's Avatar
976
New User
Default Re: as well...coolant system problem (tinkerbell)
t..
Air bubbles in coolent system? Drain and use 50/50 water honda type 2 coolent mix.
Thermo switch?
Old Jan 31, 2002 | 06:35 AM
rainforest's Avatar
Default Re: as well...coolant system problem (w00t!)
yeah just open up the radiator cap and run the car for a little that will let the bubbles out.
Old Jan 31, 2002 | 06:37 AM
KoRE's Avatar
is your car overheating also or just the heater isn't blowing hot air?
Old Jan 31, 2002 | 06:37 PM
iceburgslim's Avatar
Default Re: as well...coolant system problem (Gasoline Fumes)
Yes it does. Why do you think your heat doesnt work until your car is warmed up? It sounds like your thermostat is stuck open, making the engine run cold, and not allowing the car to warm up, thus the heat now working properly. I hope this helps!
Old Feb 1, 2002 | 04:52 AM
BoM's Avatar
BoM
Default Re: as well...coolant system problem (iceburgslim)
spend some money and get a new radiator cap and thermostat
SPOON!
check the clasifieds seen em go for 25 and 45 bucks.
Old Feb 1, 2002 | 06:08 PM
rice_classic's Avatar
he didn't say his engine was running cold..
he said that it DID come up to temperature but the heater won't blow hot air.
You might want to look at your heating system and less at your cooling system..
If my engine is too hot/cold I look at the cooling system, if my heater or a/c don't work then I look at them components. That's my story and I'm stickin' to it.
But, hey you do what you got to do!
Old Feb 2, 2002 | 05:56 AM
Default Re: as well...coolant system problem (rice_classic)
Yes Rice_Classic you are right, I must have missed that important bit of info. After seeing that, I would agree it is a heating system problem. Does you temperature control **** turn all the way? If so, does it feel normal when you turn it? Could be you temperature contol cable if it won't quite turn all the way, or it turns too freely. Also may be your heater blower motor.......so those are some things you can check. Later!
Old Feb 2, 2002 | 06:41 AM
topher's Avatar
New User
ummm, guys, i already foixed it, there was air in the system
I just re-blead it
and its fine!
JoshMerchant
Mar 13, 2015 10:27 PM
corince06
Jun 11, 2008 12:48 PM
DriveSlowHomie
Dec 7, 2006 06:57 PM
VTecLude1994
Jun 24, 2006 09:24 PM
hbkxtbone
Jun 22, 2004 08:07 AM
