head gasket prep.
Old Mar 25, 2005 | 04:33 PM
sickerhatch's Avatar
Default head gasket prep.
What is the best thing to use to clean the block and the head with before a head gasket install?
Does any one here use acetone i heard thus works well.
Old Mar 25, 2005 | 04:36 PM
acy76's Avatar
Default Re: head gasket prep. (sickerhatch)
I use brake cleaner.
Old Mar 25, 2005 | 06:52 PM
GZERO's Avatar
well, i dunno if you know everything, so i will say it anyway.
Make sure the old head gasket is off the block and off the head, you can use a blade to help you and a very fine sand paper and any solvent you like.
Then after that clean everything and pour some lubricant (whatever you have in hand) in the cilinders so the rings will have some of it in them, clean both parts (which should be shinny metal) with either brake cleaner or carb cleaner, let it dry and start putting everything back
hope it helps
Old Mar 25, 2005 | 10:54 PM
PupaScoopa's Avatar
Have a machine shop check the head for block-mating clearance (what is it, .004in?) which you have it off. The details are in the service manual...
PatrickGSR94
Jul 16, 2013 10:01 AM
D16SiHatch
25
Oct 14, 2007 02:14 AM
jdmcx
May 7, 2004 07:18 AM
3rdGteg
Oct 5, 2003 09:27 PM
rasta420
May 21, 2003 08:15 PM
