copper spray
Old Aug 3, 2009 | 08:08 AM
mehrshadvr4's Avatar
Default copper spray
is it ok to use copper spray on head gasket? the block is sleeved b18c.
Old Aug 3, 2009 | 08:41 AM
jsbayer's Avatar
Default Re: copper spray
What head gasket are you using? Is the block and head both a machine finish? We need a bit more info...
Old Aug 3, 2009 | 08:48 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It is fine on a Honda motor but there is no replacement for perfectly straight mating surfaceS (yes plural, head and block). I copper spray all my head gaskets both N/A and F/I and have never had a failure.
Old Aug 3, 2009 | 08:51 AM
stock and yes both are finished, but i want to make sure everything seals there are some scratches on head, but not on the important parrt of the head.
Old Aug 3, 2009 | 09:34 AM
HiProfile's Avatar
Copper spray won't hurt, but is a pain to clean off for a rebuild. Honda MLS gaskets use something similar to hylomar (the black stuff), and has proven to be amazing at keeping a good seal.
Old Aug 3, 2009 | 12:02 PM
jsbayer's Avatar
If both surfaces are machined smooth, copper it up!!!
Old Aug 3, 2009 | 12:06 PM
8VEYBEYB's Avatar
See I wonder about the Quality of OEM HG's I wwas going to order cometic gasket for my F/I setup but someone on here told me OEM would be fine..... I plan on running about 300-350 whp.....
Old Aug 3, 2009 | 12:42 PM
jdm inc's Avatar
^^you will be fine with oem head gasket.
Old Aug 3, 2009 | 12:59 PM
DO IT ON ALL FOURS
There are plenty of people pushing well over 600 HP on OEM Honda Head Gaskets with out problems. I have used Cometic with out problems as well. Almost any head gasket will work and give good seal if both mating surfaces are parallel.
Old Aug 3, 2009 | 04:30 PM
AJxr's Avatar
i use copper with felpro headgaskets with no problem. but if i was shooting for some serious power (450+) id go oem with no copper and FRESH CUT decks.
Old Aug 3, 2009 | 05:06 PM
8VEYBEYB's Avatar
Yup. I got both my deck and head machined so that when I am running boost I have no problems with headgaskets for a while at least
strike1545
May 24, 2010 10:42 AM
Erwan
Sep 23, 2009 09:24 AM
TeamCracka
Feb 16, 2004 06:34 PM
3rdGteg
Oct 5, 2003 09:27 PM
DLB1994
Jul 3, 2002 01:48 AM
