power steering removel
Old Dec 7, 2003 | 07:35 PM
streetracinghn's Avatar
Default power steering removel
lookn for a how to on how to make my power steering a manual one. search but it didnt really help my cat is a 91 acord lx ne help will be gratful
Old Dec 8, 2003 | 10:06 AM
doublejz's Avatar
Default Re: power steering removel (streetracinghn)
on your steering column almost on the floor you may have to pull up your carpet there is a 10 mm bolt that holds the steering column on the spline of the rack take it out,
unbolt the power steering lines on the rack,
then just take off your tie rod ends,
take out 4 bolts that hold the rack to the frame/firewall,
drop the rack (may have to take off tie rod ends off the rack to remove the rack), take off pump, take off reservoir,
find a manual rack throw it in, the passenger side will need to be drilled and tapped since the power steering rack mount is thicker then the manual one therefore the bracket won't line up with the existing holes. or make your own mount, not hard. Hope that helps some.
Old Dec 8, 2003 | 11:34 AM
Default Re: power steering removel (doublejz)
what about just takn the power steering pump and acc. out. ive heard of capn somthing off and rerouting hoses to make a manual steering rack. that is what i was askn sorry if i mislead u. lookn 4 a good step by step.
Old Dec 8, 2003 | 02:32 PM
doublejz's Avatar
oh if your just gonna use your power rack as a manual, just take of the lines from the rack and either cap them or put t breather on them. and junk the pump and acc. It will be tighter then a manual rack, power racks without the pump are deff. stiffer the manual racks
Old Dec 8, 2003 | 03:37 PM
Kendall's Avatar
Do a search, there's a kit for sale somewhere that removes the power steering and loops the lines back to a reservoir to keep the rack lubricated. It sells for somewhere close to $70 but I can't remember who sells it.
Old Dec 10, 2003 | 02:23 AM
SOHC_DK.'s Avatar
Default Re: (dc231)
Where can i buy that kit and who makes it????
M. Nielsen
Old Dec 10, 2003 | 06:26 AM
doublejz's Avatar
Default Re: (SOHC_DK.)
just look for a manuaul rack, i got one for $50 offa here
Old Dec 10, 2003 | 07:11 AM
turbologist's Avatar
Default Re: (doublejz)
Search helps...
https://honda-tech.com/zerothread?id=462824
https://honda-tech.com/zerothread?id=608220
https://honda-tech.com/zerothread?id=655043
https://honda-tech.com/zerothread?id=231914
and there are many more...HTH
Old Dec 14, 2003 | 03:06 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_DK. &raquo;</TD></TR><TR><TD CLASS="quote">Where can i buy that kit and who makes it????
M. Nielsen</TD></TR></TABLE>
The kits are currently only available for '92-'95 Civics, '96-'00 Civics, and '94+ Integras. There has been some slight interest in a 2nd gen. Integra application, and one individual purchased a '96-'00 Civic kit planning to make whatever (if any) adaptations were necessary, however I've been unable to get in contact with him to see how that worked out.
As far as the Accord mentioned above, I honestly have no experience with the Accord rack, so I would need an owner's help in developing a kit for that application.
Old Dec 14, 2003 | 05:57 PM
EXOSPEED:SHARK's Avatar
From: Azusa,CA USA/ Manila Land of the Pick Pockets
just take your power steering belt off. works the same. you can take the whole unit off later.
Old Dec 14, 2003 | 07:41 PM
RyanEJ8's Avatar
Default Re: (noVTECinside)
Check this one out... https://honda-tech.com/zerothread?id=184202
If you're not too considered with the steering effort, like I was, don't bother with the breather. It is still fairly easy to steer without it, just a little hard to park.
NOman0608
Jan 25, 2009 07:17 AM
MurdaE
Apr 12, 2008 05:58 PM
Dragginglass
Mar 27, 2008 02:36 PM
nfereorhatch
Jan 14, 2008 10:07 AM
