oil gauge install help
Old Jul 2, 2003 | 05:40 PM
toooslow's Avatar
Default oil gauge install help
is there anywhere else i can tap my oil pressure gauge on my b18c besides unhooking my oil pressure sensor and putting it there?
Old Jul 2, 2003 | 06:02 PM
quik1's Avatar
Default Re: oil gauge install help (whiteinteg95)
That is really the only place unless you hook a line to the one behind your head near the distributer. The stock oil pressure sensor is the best place to put it. Why do you want to put it elsewhere?
Old Jul 2, 2003 | 07:04 PM
toooslow's Avatar
are you talking about the 1/8" blocked fitting just below the distributor to the left? I saw that but i thought that led to the coolant?
Old Jul 5, 2003 | 04:19 PM
quik1's Avatar
Default Re: (whiteinteg95)
Its on the distributer side but the back of the head where people run the line for ls/vtec.
Old Jul 5, 2003 | 06:46 PM
b16adx's Avatar
Or you could tap it at the oil sensor and just run a T fitting there like im doing then you can use both sendors.
Old Jul 5, 2003 | 08:33 PM
quik1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 &raquo;</TD></TR><TR><TD CLASS="quote">is there anywhere else i can tap my oil pressure gauge on my b18c besides unhooking my oil pressure sensor and putting it there?</TD></TR></TABLE>
He wants to know where he can put it other then that spot.
Old Jul 5, 2003 | 11:37 PM
IN VTEC's Avatar
Use a sandwich plate to give you a pair of oil feed ports. You can use them for whatever you want. Turbo oil feed, oil cooler, gauge lines, etc.
M20x1.5mm thread size on the oil filter bolt.
Old Jul 6, 2003 | 01:10 PM
quik1's Avatar
Default Re: oil gauge install help (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Use a sandwich plate to give you a pair of oil feed ports. You can use them for whatever you want. Turbo oil feed, oil cooler, gauge lines, etc.
M20x1.5mm thread size on the oil filter bolt.</TD></TR></TABLE>
Old Jul 7, 2003 | 04:26 PM
mugenracer's Avatar
Default Re: oil gauge install help (quik1)
dont buy the GReddy plate as its fittings will only fit GReddy taps/lines/gauges(not cheap!!!)....like i found out after i bought the ******* thing!
Old Jul 8, 2003 | 03:13 PM
toooslow's Avatar
does anybody have a pic or can get a pic of the port i can use for the oil pressure gauge behind the head next to distributor. I think i know which one but not sure. Does it require an allen wrench to be taken off?
Old Jul 8, 2003 | 04:59 PM
quik1's Avatar
Yup I does require an allen wrench.
Old Jul 8, 2003 | 08:31 PM
Yellb16crxsi's Avatar
Just buy one of those Ac Autotechnic sandwitch plates that screws in between your filter and your block. I have one on mine and have no problems with it at all.
velisma
Jan 30, 2010 08:24 PM
cbabyby
Feb 27, 2007 02:36 PM
RACEPAK
Jun 4, 2006 02:34 PM
turbotime
Nov 29, 2003 04:58 PM
