Installing oil pressure and temp guages
I got an oil temp and oil pressure gauge, both electric. Both pieces that appear to need to be tapped into an oil line or something. The intrsuctions included suck, can anyone help?
Re: Installing oil pressure and temp guages (turbotime)
find the factory oil pressure sensor on the back of your block. Get a 1/8 bspt x 1/8npt fitting from z10. Remove the factory sensor and put the z10 fitting on. Then get 2 tee fittings and connect them back to back. After that connect them to the fitting from z10. Now the tee fittings give you 3 places to mount the sensors. Use one to remount the factory sensor back on and the remaining two to mount the aftermarket oil pressure and temp gauge.
Re: Installing oil pressure and temp guages (uncivilized)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncivilized »</TD></TR><TR><TD CLASS="quote">find the factory oil pressure sensor on the back of your block. Get a 1/8 bspt x 1/8npt fitting from z10. Remove the factory sensor and put the z10 fitting on. Then get 2 tee fittings and connect them back to back. After that connect them to the fitting from z10. Now the tee fittings give you 3 places to mount the sensors. Use one to remount the factory sensor back on and the remaining two to mount the aftermarket oil pressure and temp gauge.</TD></TR></TABLE>
He's talking about electric, but you would still need to find the oil pressure sensor, which is above the oil filer...on a d16, then they should have given you an oil pressure sending unit, and you need to T that into the oil pressure sensor and block, then run the wire to the sending unit
this is what h-t is all about ! Sweet I just did an oil change and I think i saw the thing your talking about when i did it. So the pressure and temp sensor both t onto that sensor that is almost directly above the oil filter in back of the block?
Thanks again
Thanks again
k im going to the store tomorrow to get these fittings, there are 2 sneding units, one for each. What size fitting to I need to fit in the stock sensor spot? Like I go into ace harware and ask for what, exactly?
Copy and pasted this one from the other post I put it in
Here is my setup, mounted it on the firewall.
I do not recommend mounting anything besides the stock dummy light on the engine. I have seen people that mounted there oil sender on there block and have it fly off on the high way. Not something you want.
Re: Installing oil pressure and temp guages (Mista Bone)
Whatever you do, don't have the oil pressure sender directly off the block. The sender is way too heavy and with the vibrations of the motor it will break off eventually. Run it like the picture above where you run a line from the block to the firewall and put the sender there. Don't forget to ground the sending unit as well.
GDM93Si
08-25-2004 10:22 AM
