oil disappearing!!!
Old 11-24-2008, 02:39 PM
gotrice16's Avatar
Default oil disappearing!!!
I'm losing a good chunk of oil pretty frequently. The motor is a B16 in a 92 cx hatch, the oil is just disappearing...
the car is not smoking blue, just fuel smoke...
all major gaskets were changed, vtec solenoid, Dizzy O-ring, oil pan, oil cap was replaced...
the car will hold oil for about a week, or 250-300 miles...
then, it just goes from full to the low dot on the dipstick in 2 days...
i've been told that honda specifies a healthy VTEC motor to only burn a quart of oil every 3 months...
so what gives? I don't smoke when i just drive around, i just smoke under heavy load...i've also been told that it is not blue smoke, so can anyone offer any insight? the only gaskets i haven't changed are the valve cover and cam cap seals.. however, if i'm losing that much oil in a 2 day process, it would be all over the motor...apart from smelling a little oil when i drive, the motor doesn't smoke...
also, my idle will hunt occasionally...it will go from 1100 to 500 and just keep hunting...
Old 11-24-2008, 03:31 PM
dschenke's Avatar
u check ur intake manifold to see if ther alot of oil in it
Old 11-24-2008, 07:24 PM
kornerk12's Avatar
what would alot of oil in the IM indicate ?
Old 11-25-2008, 08:32 AM
dschenke's Avatar
valve seals leakin
Old 11-25-2008, 05:01 PM
95vxtealhatch's Avatar
Your leaking oil in a place you can't see.
Old 11-26-2008, 03:30 PM
twentyhurtz's Avatar
look on back of block, look around oil filter, look at bottom of cap on distributor as well as distributor to head, check valve cover gasket, front of block, even down under main pulley where bottom of timing belt is, and rear main seal where bottomo of tranny is.
Old 11-28-2008, 05:29 AM
GSR_hatch936's Avatar
Is the motor leaking any oil is the first question. Also if ur blowing smoke out when u get on it or in vtec means u need to bore over ur block or get new rings.
Old 11-28-2008, 09:27 AM
gotrice16's Avatar
it's not oil burning smoke, which has blue tint...
It's just fuel smoke, which is black...
i can't locate any leaks...my rear main seal is relatively new, it's only seen 1'000 miles
i've checked the pcv, it clicks and functions normally...
any other reasons why my idle might be hunting?
and why i'm consuming oil like a fiend?
Old 12-01-2008, 07:51 AM
naseem's Avatar
i have the same problem..i have a b16a5 it runs very good but approx 1 litre oil disappears every 300-350km. i dont have any oil leaks from anywhere and no smoke coming out except fuel smoke which is black when i push hard on the pedal.
Old 12-01-2008, 08:16 PM
mouab18c1's Avatar
i believe my uncles eg did the same with a jdm b16..fed the sucker a bottle every other day..thought it was the hg but somehow when he decided to rebuild it one of his rod was all bent up in shyt...funny thing was that it ran fine..that could be a possiblity
Old 12-02-2008, 09:47 AM
Dang i wish i had cool relatives with honda's!
Old 12-02-2008, 10:28 AM
mouab18c1's Avatar
tell me about it...i have buddies families & friends that drive honda's..ahahaha
Old 12-02-2008, 02:36 PM
gotrice16's Avatar
my closest friends drive hondas....
my dad drives a 2002 CRV with a JDM ITR head, i helped him build...
it's factory otherwise...the factory air box was reused.
Old 12-02-2008, 09:02 PM
mouab18c1's Avatar
so you figure why your loosing oil?
Old 12-03-2008, 01:23 PM
gotrice16's Avatar
no...
i put some STP oil treatment in, it's been doing okay this week...
i've been driving like a fiend, though..i've been in a little bit of a hurry lately...
Old 12-03-2008, 01:46 PM
mouab18c1's Avatar
i suggest take it to the shop the get a leak down test done...for your own safety..its either eating or leaking...
Old 12-03-2008, 02:34 PM
Banned
johnlear's Avatar
Black smoke = running rich.
Engine hunting = running rich.
Losing oil with no external leak = burning oil.
Black smoke is masking blue smoke...
Old 12-05-2008, 09:38 AM
gotrice16's Avatar
okay, the results of the compression test are in...
165, 150, 125, 160
125 in the 3rd cylinder...
we put a teaspoon of oil in the cylinder, it raised it to 160..
oil rings are shot...
the wierd thing is, the plugs are white and clean...so, could it be piston rings or valve seat?
Old 12-05-2008, 10:02 AM
tagperformance's Avatar
sounds like you washed the rings and cylinder walls by running the car too rich. too much gas will thin out the oil between the rings and cylinder walls causing excessive wear to the point where it causes blow-by and burning oil. next time around make sure your car is properly tuned.
Old 12-05-2008, 04:59 PM
gotrice16's Avatar
ok...that makes sense...
i bought the car with the fuel pressure regulator set the way it was, i never changed the fuel pressure so far...
i bought the car from a stupid kid that ran it as rich as possible, trying to go for that backfiring, fire-ball, wake-the-dead approach...
i'm just gonna drive this one the way it is, i have an LS motor i'm building, as soon as i'm done i'll just drop it in and rebuild the B16 bottom end for a ridiculous turbo setup...i'll probably drop in an 88-91 and go for a Ferrari-style build...
what i mean, is something that has a great port job on the head, revs at about 9500, turbo, and making about the same power as an F355 Challenge...
i like to use other cars as influences in my builds... I had the Mazda CX-7 in mind when i build my dad's CRV, and i had the Type R in mind when i built an EG i had before, it had an integra dash and nice stitching in the interior...
i don't like to just think Civic when i build something...because, to me, a stock civic is in the same category as a Camry, or Corolla, or something that a grandma or a fratboy yuppie would drive around...
now, the JDM civics are nice, because they actually perform, they aren't just econo-boxes..
IntegraType-R
25
11-05-2007 04:58 PM
d!ckface
16
07-27-2007 04:35 PM
stevescivic
06-17-2006 12:57 PM
Nextelbuddy
05-30-2003 07:50 AM
Pinpid
12-17-2002 04:55 PM
Quick Reply: oil disappearing!!!
