Mild Smoking in Vtec?
Ever since i had my motor (b18c) it smoked when vtec engauged. but ever car i see with a swap tends to smoke to. but since i put an exhaust on my car it seems to burn more and covers the back of my car in sout. anyone have any ideas why im burning oil?
Re: Mild Smoking in Vtec? (GSRh@tch)
The conventional oil used in those motors will cause a coking of the oil control rings, and will eat oil under high speed, a good compression test will verify that. If it is more of a whitish smoke it could be leaking from the exhaust valve guides. (take a drop of oil and put it on your hot header and tell me it doesn't burn up white, blued smoke indicates oil that is combusted.)
Some of those cars may never have seen an oil change, which will only make things worse of course, a good synthetic motor oil will help break down the coking, as it did for my car after running it for around 8,000, and now no more blue.
You also must remember that at 8000rpm, the oil jets are putting a lot of oil on the piston, and some will squeak by whether we like it or not.
Re: Mild Smoking in Vtec? (slowcivic2k)
so should i use a full synthetic or a blend. i hear it isnt good to go right to full sythetic from coventional oil..
Im having the same problem....But When I see it in my Rearview Its black..And thats when I dump it!! and thats what my peeple tell me when they r behind me. But Im also short on oil when I check it in the mornings after I was running or doin high speeds or high rpms the night bfore
Also what are the steps coming from conv oil to syn??
Re: (BlkCivicFromTeamMNR.com)
the smoke is black. it doesnt smoke if i baby the car, but after crossover it will. my friends em1 does it too but not as much as mine.
been there done that
Re: (GSRh@tch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si »</TD></TR><TR><TD CLASS="quote">b series smoke in vtec....fact of life</TD></TR></TABLE>
mine doesnt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch »</TD></TR><TR><TD CLASS="quote">the smoke is black. it doesnt smoke if i baby the car, but after crossover it will. my friends em1 does it too but not as much as mine.</TD></TR></TABLE>
you're running rich
mine doesnt
you're running rich
Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
mine doesnt
you're running rich</TD></TR></TABLE>
Mine neither.
mine doesnt
Mine neither.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkCivicFromTeamMNR.com »</TD></TR><TR><TD CLASS="quote">Also what are the steps coming from conv oil to syn??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch »</TD></TR><TR><TD CLASS="quote">so should i use a full synthetic or a blend. i hear it isnt good to go right to full sythetic from coventional oil..</TD></TR></TABLE>
lies...
get a quality oil flush (i suggest JB aka Justice Brothers. Any quality shop will most likely carry it like we do) run it for about 700 miles, and drain the oil. then swap over to Amsoil.
Best stuff out, and cheaper in the long run. change the filter every 5,000 miles, and change the oil every 20,000. Can't beat it!
But as far as swapping over to a full synthetic, just change the oil next with synthetic. a quality synthetic like Amsoil or Mobile1 will blend with whatever is left in the crankcase. So it won't cause any trouble.
lies...
Justice Brothers offers alot of different additives. which do you suggest the most?
Link: http://www.justicebrothers.com...s.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling »</TD></TR><TR><TD CLASS="quote">
20k w/o an oil change thats laughable.
Yeah I was thinking the same thing but he says change the filter every 5k lol. If he drives like the rest of hondatech than he'll have serious problems
