OBD1 Conversion....
Old Apr 30, 2005 | 10:43 AM
InTeGrA GsR 321's Avatar
Default OBD1 Conversion....
I want to convert my 97 GSR to OBD-1...I know I need an ECU and wire harness, but what ECU should I get and else do I need ??? Someone mentioned something about OBD-1 injectors and injector clips...Are they needed ???
Old Apr 30, 2005 | 01:01 PM
eda6's Avatar
Default Re: OBD1 Conversion.... (InTeGrA GsR 321)
Here's what you need
obd1 or obd2 b-series vtec distributor
4 wire o2 sensor
obd2-->obd1 conversion harness
p72 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA GsR 321 &raquo;</TD></TR><TR><TD CLASS="quote">Someone mentioned something about OBD-1 injectors and injector clips...Are they needed ???</TD></TR></TABLE>
no. Your obd2 injectors will work.
Old Apr 30, 2005 | 01:39 PM
Default Re: OBD1 Conversion.... (eda6)
Why would I need an obd1 or obd2 vtec distributor if I have a GSR (vtec) ??? And what's the difference between the P72 and P28 ???
Old May 2, 2005 | 07:23 AM
bump
Old May 2, 2005 | 08:12 AM
Katman's Avatar
ok, more info is needed ...
Are you wanting to pull your 97 GSR motor in favor for an OBD1 motor? or do you just want to change your ecu to OBD1 spec?
If just the ecu is all you want to do, all you need is an OBD2A-&gt;OBD1 jumper harness and OBD1 P72 ecu. NO need to convert your injectors, distributor, etc. to OBD1, just the ecu side is all that needs to be changed.
P72 is a GSR ecu, P28 is a SOHC VTEC ecu which can be reprogrammed to DOHC VTEC spec. IMO, its best if you find a stock OBD1 GSR (P72) ecu.
JdM_Eg6_SiiR
Engine Management and Tuning
Dec 6, 2010 07:12 AM
98_ssbp
Aug 25, 2010 06:28 AM
BoltonGSR
Jun 13, 2008 08:49 PM
2.2 teg
Oct 20, 2005 08:21 AM
B18 CYA
Apr 28, 2004 09:58 AM
