OBD1 Conversion....
I want to convert my 97 GSR to OBD-1...I know I need an ECU and wire harness, but what ECU should I get and else do I need ??? Someone mentioned something about OBD-1 injectors and injector clips...Are they needed ???
Here's what you need
obd1 or obd2 b-series vtec distributor
4 wire o2 sensor
obd2-->obd1 conversion harness
p72 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA GsR 321 »</TD></TR><TR><TD CLASS="quote">Someone mentioned something about OBD-1 injectors and injector clips...Are they needed ???</TD></TR></TABLE>
no. Your obd2 injectors will work.
4 wire o2 sensor
p72 ecu
ok, more info is needed ...
Are you wanting to pull your 97 GSR motor in favor for an OBD1 motor? or do you just want to change your ecu to OBD1 spec?
If just the ecu is all you want to do, all you need is an OBD2A->OBD1 jumper harness and OBD1 P72 ecu. NO need to convert your injectors, distributor, etc. to OBD1, just the ecu side is all that needs to be changed.
P72 is a GSR ecu, P28 is a SOHC VTEC ecu which can be reprogrammed to DOHC VTEC spec. IMO, its best if you find a stock OBD1 GSR (P72) ecu.
2.2 teg
Oct 20, 2005 08:21 AM
