B17a Head + B18c1 Block
Old May 1, 2005 | 08:33 PM
P_t0wn's Avatar
Default B17a Head + B18c1 Block
I was looking into getting a b17a head to match with my b18c1 block. I've already done a search and i found little information about that setup. I was looking for anybody that has or had some experience with this setup. Any information at all would be awesome...
Thanks for the help.
Old May 2, 2005 | 12:10 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: B17a Head + B18c1 Block (P_t0wn)
its the same as a b16a head, search under poor mans type r, you will also loose about .5 in compression.
Old May 2, 2005 | 05:29 AM
P_t0wn's Avatar
Default Re: B17a Head + B18c1 Block (PURPLETERROR)
.5 from what a gsr should be, or what the compression would be with the b16 head
Old May 2, 2005 | 08:08 AM
P_t0wn's Avatar
bump
Old May 2, 2005 | 08:12 AM
mmuller's Avatar
Mad Scientist
with the pr3 head you loose .2 compression over the p72
Old May 2, 2005 | 08:15 AM
Katman's Avatar
stock US GSR engine puts out 10.1 cr
putting a B16A head on withh lower the CR to about 9.8...almost perfect for turbo compression.
check out the CR calculator here:
http://technet.ff-squad.com/cr-calculator.htm
zcme
Mar 2, 2008 04:12 PM
deanh8
Jul 14, 2006 06:39 PM
skittyscott
10
Dec 8, 2004 04:41 PM
EG617
Dec 5, 2004 12:01 AM
