On to the next question..
Old Jul 16, 2002 | 12:44 PM
hondacivic4g's Avatar
Default On to the next question..
Ok, I've got the A/R effect, functions and tools for the process figured out.
Now, do I need to adjust the timing in conjunction with the A/F increase?
Or can I to achieve greater performance by adjusting the timing in conjuction with the Air/Fuel increase?
And how or what would be the ideal setting , and or how do i find it?
Thanks
Old Jul 16, 2002 | 10:43 PM
liam821's Avatar
Default Re: On to the next question.. (hondacivic4g)
Thanks
The only real way to find the ideal setting is going to a dyno and start tuning and trying things. Depending on what compression you motor is..you can only go so far before you will get knock. You can adjust the timing by moving the distrubtor and of course cam timing with a cam gear.
liam
jdm420da6
Jul 30, 2005 12:16 PM
PHiZ
Feb 24, 2004 07:27 PM
Lazydsm
Feb 6, 2003 06:47 AM
honda8882
Sep 29, 2002 11:28 AM
