Building for Boost!!
Old Jun 27, 2002 | 07:01 PM
xpurespeedx's Avatar
Default Building for Boost!!
Just wanted to get everyones opinion on what I should do. I dont want to go with a B-series, I am sticking with the sohc. I have a d16a6 engine that I want to rebuild because I am building a custom turbo setup. If I only run a max boost of about 10 psi should I just put stock internals back in the block or should I get some je pistons and new rods or do you think the stock stuff should be fine. What are some of your guys SOHC turbo setups? Thanks
Old Jun 27, 2002 | 08:51 PM
b18turbocivic's Avatar
Default Re: Building for Boost!! (xpurespeedx)
The way i see it ....if you are gonna go inside the block you might as well get some stronger stuff specially if you want to run high boost. JE pistons and Eagle rods are a very good and strong combo, or you could use Endyn pistons those are too.
Just my .02
Jap_Spec_Imports
Mar 17, 2008 07:41 AM
bboysake
Aug 11, 2006 03:02 PM
altz
Feb 25, 2006 06:30 PM
SpoolnByYou
Dec 19, 2005 02:28 PM
1.8T_EG
Apr 2, 2003 02:54 PM
