More ECU stuff
Old Dec 6, 2003 | 12:45 PM
AngelTeg's Avatar
Default More ECU stuff
I was doing a search on here because I wanted to learn more about Fatory honda ECUs. I dont care a ton, because I'm running a standalone, but I wanted to be informed in case someone asked me.
My question is based on the fact that I went to a website, and saw "P28" and then next to it "OBD1 92-95 civic si/ex" those are both D-series motors, but whenever you hear about ecu's, you always hear about P28 ECUs. so I was wondering if you can indeed use this D series ECU with a B series motor, without problems, and also, that implies that the same can be said about wiring harnesses?
thanks for the help
-Mike
Old Dec 6, 2003 | 06:51 PM
TRuST's Avatar
Default Re: More ECU stuff (AngelTeg)
Yes, the pin outs are the same. Except the P28 does not use the Knock Sensor nor control the secondary butterflies. So, if you have a B-series motor without a dual plane manifold you should be able to run a P28 or P30 without any problems.
Old Dec 6, 2003 | 06:53 PM
mmuller's Avatar
Mad Scientist
Default Re: More ECU stuff (TRuST)
you also need to get it chipped for dohc
Old Dec 6, 2003 | 10:59 PM
dohcnotec's Avatar
Default Re: More ECU stuff (mmuller)
I don't know anybody that doesn't run a B-Series with a chipped P28
Charlie Moua
Sep 28, 2017 07:30 PM
SL_RICK83
Mar 5, 2006 07:46 PM
Jammersplace
Oct 24, 2004 07:35 PM
Dent Free
Dec 7, 2003 09:27 AM
MeanGreenEG9
Dec 2, 2002 09:59 AM
