moates burner question
Old Jul 26, 2006 | 04:42 PM
WolfGod's Avatar
Default moates burner question
i need some help here... im trying to upload a map to my chip (27SF512) which is on the supported list... and every time i try to verify it aginst the buffer it comes back negative and when i save what the chip has and read it its one setting all the way across in the fuel and timeing tables and the injector size is totaly fucked over
anyone know what i'm doing wrong?
im inserting the chip correctly, i have the coms and everything configured correctly (what the site reccomended) and cant figure out whats going on
i load a bin, burn it, and the burn program still says its blank
Old Jul 27, 2006 | 01:39 AM
Enzo Speed's Avatar
Default Re: moates burner question (WolfGod)
Wait, are you trying to burn a chip or read a chip? Because if you try to read one, it usually doesn't work and when you open it in UD all the cells are corrupted.
Old Jul 27, 2006 | 01:40 AM
Enzo Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WolfGod &raquo;</TD></TR><TR><TD CLASS="quote">
i load a bin, burn it, and the burn program still says its blank</TD></TR></TABLE>
Are you selecting the correct eprom from the drop down menu? You actually have to click on which eprom you're using.
Old Jul 27, 2006 | 01:43 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: moates burner question (Enzo Speed)
Make sure you have the latest version of Flash'n'Burn, and are using a good chip. I've has this issue too, and it turned out that it was writing to the chip in the wrong "area". The updated Flash'n'Burn software helped me fix this.
What are you using for a program? I recommend Crome...
Anyways, do this: ERASE the chip first. Then load the file to the buffer, burn, and verify chip w/buffer.
See if that helps.
Old Jul 27, 2006 | 01:44 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: moates burner question (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed &raquo;</TD></TR><TR><TD CLASS="quote">Wait, are you trying to burn a chip or read a chip? Because if you try to read one, it usually doesn't work and when you open it in UD all the cells are corrupted.</TD></TR></TABLE>
Works for me everytime. I think your problem is Uberdata.
http://www.tunewithcrome.com
Old Jul 27, 2006 | 01:46 AM
Enzo Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.tunewithcrome.com</TD></TR></TABLE>
Yeah, probably. I can load a file to the burner, burn the chip, then turn around and read the chip and open the file in Uberdata and suddenly everything is fucked. There will be like 20 random fuel cells that all change to -5.
Old Jul 27, 2006 | 01:50 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Yeah, probably. I can load a file to the burner, burn the chip, then turn around and read the chip and open the file in Uberdata and suddenly everything is fucked. There will be like 20 random fuel cells that all change to -5.</TD></TR></TABLE>
Yea, I was having the same issues. I hate Uberdata. Crome FTW!
Old Jul 27, 2006 | 07:59 AM
WolfGod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you have the latest version of Flash'n'Burn, and are using a good chip. I've has this issue too, and it turned out that it was writing to the chip in the wrong "area". The updated Flash'n'Burn software helped me fix this.
See if that helps. </TD></TR></TABLE>
thats the exact process i do, and every time it say's failed... i read the chip and click edit buffer and all there is, is F's and 0's
i've tried burning crome and uberdata maps and it doesnt matter which i use, every time i do the blank check it says the chip is blank, and every time i try to verify it says failed
im thinking the chips could possibly be bad but i dont know how.. i got them with my ecu and they've been sitting in my glove box in a plastic case untill now
Old Jul 27, 2006 | 08:01 AM
WolfGod's Avatar
BTW the moates program says im useing V. 5.10.F
the newest one on there site is 5.9
i just ordered my burner about 4 days ago
Old Jul 27, 2006 | 06:49 PM
WolfGod's Avatar
anyone have any other ideas? i ordered some new chips to see if maybe the chips i have are bad...
Old Jul 28, 2006 | 01:38 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WolfGod &raquo;</TD></TR><TR><TD CLASS="quote">BTW the moates program says im useing V. 5.10.F
i just ordered my burner about 4 days ago</TD></TR></TABLE>
Update to the current version. Its a free download.
Old Jul 28, 2006 | 09:49 AM
WolfGod's Avatar
how is 5.10 not more current then 5.9
Old Jul 28, 2006 | 12:26 PM
WolfGod's Avatar
Update to the current version. Its a free download.</TD></TR></TABLE>
updated to 5.9 (which i still dont see how you say thats the current version with the burner running 5.10) and have the same problem, still wont burn
lkailburn
Dec 31, 2015 03:03 PM
95BoostedEJ1
Engine Management and Tuning
20
Jan 23, 2010 06:55 PM
ericschimmel
Jun 18, 2007 06:47 AM
JrCRXHF
Jul 12, 2005 09:16 PM
the.hamburglar
Mar 20, 2005 04:51 PM
