milkshake on valve cover cap
Old Dec 25, 2008 | 08:14 AM
onoitsaldrin's Avatar
Icon4 milkshake on valve cover cap
hey guys i just did an ls/vtec swap on my car and im getting milshake on the valve cover cap but not on the bottom...my major concer is if the heads crack or leak on the head gasket.....
so far all ive done is do a compression test... the compression is 210 on all 4 cylinder i cranked it 5 times.....and so what else could it be i also dont have a breather chamber installed would that have anyting to do with it cause i read online that breather chambers are suppose to eliminate the vapors that are rising up to the head
http://www.freepatentsonline.com/6415778.html
Old Dec 25, 2008 | 08:54 AM
Jas9848's Avatar
Default Re: milkshake on valve cover cap
a milkshake type of build up in either the oil or coolant would be a mix of the two, most likely from the headgasket. you might want to check the coolant and see how that looks. alot of times on ls/vtec builds, the plug in the head doesnt get smoothed out properly and makes the head sit up a little bit and doesnt allow the head gasket to seal properly.
the hole in the bottom of the block is where the black box connects to and then to the nipple up higher. then the pcv on the top of the black box is run to a port on the intake manifold. the way you have it set up now, you are probably burning some oil. i would reconnect it the way it's supposed to be.
Old Dec 25, 2008 | 09:50 AM
dbiker207's Avatar
could just be some condinsation on the cap. is there alot? maybe take some pics. the other thing you could do is a leakdown test and listen to where the air is coming from (oil fill, radiator,...)
Old Dec 25, 2008 | 11:10 AM
b20vtek's Avatar
that sound like the coolant the oil are mixing chek your headgasket
Old Dec 25, 2008 | 11:39 AM
hayabusa160's Avatar
i got that sometimes but it was becuase i didnt drive the car for a long periods.
Old Dec 25, 2008 | 01:21 PM
mouab18c1's Avatar
what he said...the plug is a common problem if not tightend all the way so that it doesnt stick out...i had this problem with my b20vtec while having good compression all across and going through a shyt load of hg's..
Old Dec 25, 2008 | 05:59 PM
lude98SH's Avatar
I had this happen to me. Drove me crazy trying to figure it out, I let it warm up completely drove it abit and problem solved.
Old Dec 25, 2008 | 08:16 PM
mouab18c1's Avatar
im having the same problem...had water in my coolant system and degrees went below zero..freaking h20 froze on me so i had to drain it out and put it coolant in it...after that i drove for about half a mile and had a little mixture on my oil cap....im praying its not my hg....but then again what you guys where saying, i didnt drive it for a few days in the freezing weather so im hoping thats the problem...but in his case if its alot then its either the plug or hg....could also be coolant line plugged in wrong...
Old Dec 27, 2008 | 10:52 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
condensation must likely, nothing to worry about.
Old Dec 28, 2008 | 12:10 AM
rip94delsol's Avatar
That hole on the bottom comes capped or not opened up like that from the factory. I just got a block like this for the first time. I have never seen that before!
Old Dec 28, 2008 | 12:33 AM
UJLSMoFo's Avatar
im not sure what years, but some ls didn't come with breath boxes.
Old Dec 28, 2008 | 04:25 AM
slomofo's Avatar
GDD Member
If it's snowing outside or there's heavy rain, the vanilla shake or chocolate milk under the cap is normal.
Old Dec 28, 2008 | 05:02 AM
IN VTEC's Avatar
I see it a lot when doing oil changes during the colder months of the year and the oil hasn't gotten warm enough to vaporize all the condensation. Don't worry about it.
Old Dec 28, 2008 | 07:30 AM
Andrew-L's Avatar
ive got two B18B1's, and one has the breather box, one doesnt. does the one without come from a newer model integra?
Old Dec 28, 2008 | 04:36 PM
more than likely its an older motor. OBD-0. 93 and below!
Old Dec 28, 2008 | 05:40 PM
Andrew-L's Avatar
so non-breather box blocks come from older cars correct?
Old Dec 28, 2008 | 06:03 PM
srmofo's Avatar
NO, non breather box ls engines are obd2 ....I just got one from GE and it has the vin plate on the front, does yours?...., my 95 obd1 had a breather box, my newer one from GE does not...BTW thats just condesation if its only on your cap, nothing to get too anxious about....if it worries you, just put a catch can off the front of the valve cover
crxvtec16
Nov 29, 2008 01:00 PM
rice a roni
May 31, 2006 07:18 PM
fastrunner
Apr 27, 2005 07:06 PM
B18c1turboedEK
Jun 10, 2004 07:53 AM
AGPSuperstar
Feb 17, 2003 12:15 PM
