B16A...Blown? IDK!!!
Old Nov 28, 2008 | 06:54 AM
crxvtec16's Avatar
Default B16A...Blown? IDK!!!
Ok, this started about a month ago i noticed i could hear a difference in the way it turned over at starting. i also noticed a lot of oil dripping out from the breather on the valve cover. Did a compression test and the no.1 cylinder had about 70 . I thought it could of been my head gasket or valves so i pulled the head off cleaned up and re-seated the valves and changed my head gasket. Put it all back together and still had the same problem....I had my friends head lying around so i figured i would throw that on just to make sure it wasn't anything else in the head and it still does the same thing.....The only other thing i would think it is is my piston rings?? anyone have any ideas? i want to make sure i do not have anything else wrong before i pull the motor in this cold a$$ weather.
Thanks
Old Nov 28, 2008 | 08:00 AM
kp's Avatar
kp
Thanks
Do another comp check but before you do, pour a bit of oil into the cylinder through the spark plug hole. Leave it for a minute so the oil has a chance to coat the whole circumference of the piston rings. Then crank it over again, if it's a big improvement from your established 70 psi, then it's 99% your piston rings that need replacing.
I did this on my B16A when I was comp checking it, #1,2 and 4 were all 200 psi and 3 was about 190 or so. I poured some oil into #3 and it went up to about 230 or 240. Huge difference. Keep in mind the engine was sitting on the floor, it hadn't been ran in a while so the 200 psi readings would be more if there was some oil on the cyl walls.
Old Nov 29, 2008 | 07:27 AM
toddone's Avatar
I bet the ring land on the piston is broken.
Old Nov 29, 2008 | 01:00 PM
crxvtec16's Avatar
I did another compression test and it was fifty in the cyllender that was bad, then i squirted some oil in the cyllender and the compression bumped up to one hundred, im thinking its the rings and im gonna pull the engine this week....fun fun
ehrkeith
10
Apr 16, 2012 05:54 PM
dc2_dailydriver
Feb 25, 2009 07:28 AM
civicegsick
Feb 1, 2009 06:24 AM
typeR#0427
Mar 17, 2005 10:28 AM
Yuleluder
Sep 16, 2002 09:43 AM
