Installing Valve seals (searched)
Old Nov 4, 2003 | 08:13 AM
Ryan C's Avatar
Default Installing Valve seals (searched)
i guess the hard part is over (gettin them bastards out)
now i need to put the new ones in.
Honda has a nifty tool that holds them just right and then you put them in with a plastic mallet and bla blah blah.
can i just put these suckers in by hand or what?
how do you guys do it?
i know there has to be a ghetto way!
Old Nov 4, 2003 | 09:09 AM
owen_the_soyboy's Avatar
Default Re: Installing Valve seals (Ryan C)
I used the ghetto way... found a deep socket for a ratchet that had a inner hex the same size as the od of the top portion, I was able to set them on there by hand and tap the socket with a rubber mallet. make sure to not dent the base of the valveseal and also, I put the valve in the valveguide while I seated the seal by hand to make sure I was getting the seal on there straight.
worked like a charm
Old Nov 4, 2003 | 09:48 AM
Ryan C's Avatar
Default Re: Installing Valve seals (owen_the_soyboy)
lol, thats exactly how i planned on doin it, thanks
Old Nov 29, 2003 | 09:01 AM
Ryan C's Avatar
back from the dead.
how far in should the seal go?
i'm pretty sure mine are in right but there is still a little gap between the bottom of the seal and the to ridge on the guide.
does that sound right?
Old Nov 29, 2003 | 09:23 AM
IN VTEC's Avatar
yup
jasoncrashtech
May 25, 2013 08:10 PM
Kr4nG
Nov 2, 2009 01:53 PM
amy
16
Apr 29, 2007 12:19 PM
Civicr2gs5
21
May 6, 2004 12:44 PM
1.8EG-T
Dec 14, 2003 02:56 PM
