installing valve stem seals??
okay so i took off all my valve stem seals and i wann install my new ones on...when installin valve stem seal, is there anything else i need to add with it such as lubrication or just put them on as it is....??? any feedbacks will help
Re: (moto27cm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm »</TD></TR><TR><TD CLASS="quote">Metal:
A little silicone around the rubber seal doesnt hurt. They can be put in dry too.
Rubber:
Havent done these myself. I think they just pull through.</TD></TR></TABLE> so just silicone around the metal....wut about when puttin the valve stem seal on that lil circle metal thingy?
Rubber:
Re: (m3dia_lab)
if there rubber use a lil grease and yank um through just be careful not to cut the stem. I have never done a metal one so i can't give exact advice on that. It is pretty self explanatory. If any thing go pay the 5 bucks and get them put in.
Global Moderator
Re: (moto27cm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm »</TD></TR><TR><TD CLASS="quote">Wait a minute. Are you talking about valve stems for wheels or VALVE SEALS for your head?</TD></TR></TABLE>
Exactly what i'm wandering..
Global Moderator
Re: (Civicr2gs5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicr2gs5 »</TD></TR><TR><TD CLASS="quote">Valve Stem Seals...if u would read my FIRST post u guyz wouldn't have this problem </TD></TR></TABLE>
Either way it didn't make sense.
No need to be a SMARTASS
1 Post
Re: (moto27cm)
What a bunch of **** ups in here.
There is no such thing as a valve stem seal in the head. It is simply called a valve seal.
To the original poster: When people ask you a question don't respond with mindless babble, try answering the question. It takes a lot less effort when you do that.
Ignorant people **** me off.
1 Post
Re: (Civicr2gs5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicr2gs5 »</TD></TR><TR><TD CLASS="quote">Valve Stem Seals for the head</TD></TR></TABLE>
Then you most definately do not want to just pull them through the valve spring. Compress the valve spring, place the seal and keepers on the valve and then decompress the spring.
Once again, there is no such thing as a valve stem seal in the head.
Re: (Civicr2gs5)
Alright. "head" being the magic word there. They are typically called valve seals, not valve stem seals.
The S/M doesnt say anything about lubing them. It does however, recommend a special driver that fits the seal perfectly. It probobly costs a lot. You can use any driver that wont harm the rib at the top part of the seal. Hope that helped.
Risky Business
Re: (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">I'm done helping people who have no common sense.</TD></TR></TABLE>
I'm done with this thread.
