Master Kill Switch Wiring
Old Mar 19, 2009 | 06:35 PM
boostedb20z's Avatar
Default Master Kill Switch Wiring
how did you guy wirer your??? my switch ans battery are in the back of my hatch right now i have the battery though the switch but im kinda stumped on how to kill the car for good alt wirer or dizzy wire. how did you guys do yours thanks
Old Mar 19, 2009 | 06:47 PM
mmuller's Avatar
Mad Scientist
Default Re: Master Kill Switch Wiring
you can wire a kill switch to the fuel pump, either by a strong switch or wire an additional relay to use the kill switch with
you can use power to injector to wire a kill switch also
Old Mar 19, 2009 | 06:53 PM
JOE BD-0's Avatar
On most EF's you just need to interrupt the battery and the alternator supply wires. They are at the same point on the side of the fusebox that is towards the front side of the car (on EF's). Good Luck.
Old Mar 19, 2009 | 08:44 PM
that wouldnt work cuz the alt will still put power into the fuse boxs running everything else
Old Mar 19, 2009 | 09:50 PM
JOE BD-0's Avatar
i dunno, it works on my racecar. you could interrupt the coil wire at the dizzy. good luck
Old Mar 20, 2009 | 05:44 AM
fcm's Avatar
fcm
Old Fart
Install a switch on the ground to the PGM-FI Main Relay, [black wire] it is the ground to the injector relays coil so it is a "low" current ground requiring only a small, easily hidden, 1A switch.
It will shut down the injectors, fuel pump, a 12V+ to the ECU and some engine sensors.
Lot's of birds with one small stone. 94
BTW, disconnecting the batt. is not a good way to go, you lose ECU memory.
Old Mar 23, 2009 | 05:59 PM
civichb95lnd's Avatar
I will be finishing my battery relocation and kill switch install tomorrow, but here is a diagram i found on honda-tech that should be helpful.
turbo-crx
Jan 9, 2009 09:58 AM
underpressure02
Apr 23, 2007 08:42 AM
fe519
Jan 28, 2005 08:19 AM
Simple
13
Jan 10, 2004 07:57 AM
Jeff_G
Sep 30, 2002 01:35 PM
