Inspecting a motor which is out of a car?
Old Nov 2, 2005 | 05:34 PM
tianporn's Avatar
Default Inspecting a motor which is out of a car?
Im not sure if this question has been asked before, but what preventative checks can you do to a motor which is out of a car?
What should be the areas to inspect? Obviously you cant really crack the motor open and see.
Can you do a compresion test and leakdown test with the motor out of the car?
Cheers
Old Nov 2, 2005 | 07:26 PM
projectTeG's Avatar
i know that you can spin the motor(crank bolt) and see if everything spins. removing the valve cover also hel in the inspection while turning the engine.
Old Nov 2, 2005 | 07:41 PM
corradoproblem's Avatar
Default Re: (projectTeG)
dont get ripped off (like i did) i bought a used b18a1 and it turned out it needed a rebuild. check for signs of overheating, leakage anywhere around the head. see if he will let you take off the valve cover. check that the oil doesnt seem burnt(smells bad really black) check for heat discoloration on the camshafts, rotate the engine and make sure it feels like it has compression. the inside of the head should wipe reasonably clean, if the aluminum is stained bad its got many miles or overheated or both, check condition of vaccum lines and hoses to determine overall age and maintence level. check spark plugs to see how it was running. if the guy wont let you do these things dont buy it. too many crap engines out there
Old Nov 2, 2005 | 09:47 PM
tianporn's Avatar
Default Re: (corradoproblem)
Good info. Keep it coming? Could I do a compression test by just tapping the starter to a battery?
Old Nov 3, 2005 | 02:51 PM
tianporn's Avatar
Default Re: (tianporn)
Ok just realised comp test will be hard since the motor is gonna be cold haha.
BUmp
Old Nov 3, 2005 | 02:59 PM
rainforest's Avatar
cylinder leak down test. thats the only good way of checking with the motor out of the car.
Old Nov 3, 2005 | 03:27 PM
Lord Helmet's Avatar
Default Re: Inspecting a motor which is out of a car? (tianporn)
Pull the valve cover off and inspect, do a leakdown test, and if you have a engine hoist or stand pull the oil pan and inspect the crank, rods, etc...
Old Nov 3, 2005 | 03:28 PM
projectTeG's Avatar
Default Re: Inspecting a motor which is out of a car? (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">Pull the valve cover off and inspect, do a leakdown test, and if you have a engine hoist or stand pull the oil pan and inspect the crank, rods, etc... </TD></TR></TABLE> that too
jonyi27
Nov 29, 2012 10:22 AM
SiYouLater
Oct 23, 2008 10:27 PM
pnoyboldstar
Apr 7, 2007 05:48 PM
drumminforev
27
Oct 9, 2006 12:56 PM
sixFifty_ek9
Jun 23, 2005 06:21 AM
