How to tell if a motor is blown!?
How would someone check if a motor is blown without installing it in a car. Is there a way to visually inspect and check for play....and where would i check.
Re: How to tell if a motor is blown!? (drumminforev)
any huge gaping holes in the block
also you could get an VERY ROUGH guesstimate as to the health of the compress give her spin of the crank and there are 3 stiff parts well then you might have something wrong with a cyclinder.
you can always pull the head
Re: How to tell if a motor is blown!? (EX-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">Do a compression and leakdown test. Those should tell you the working order of the motor.</TD></TR></TABLE>
Compression test....so im gonna crank the expletive out of it with my hands for that....would it be accurate.
any way to tell For rod knock/any bottom end damage. I know leakdown will tell piston rings, but what about crank.
Re: How to tell if a motor is blown!? (noz79)
****, you should get a harness, ecu and a gas can and start the bitch up. jk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noz79 »</TD></TR><TR><TD CLASS="quote">Attach the starter to it and crank it with some jumper cables to do the tests. </TD></TR></TABLE>
Good idea. Ill have my buddy hold the engine steady on my floor while i hold the starter up to it with my hands.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev »</TD></TR><TR><TD CLASS="quote">Good idea. Ill have my buddy hold the engine steady on my floor while i hold the starter up to it with my hands.</TD></TR></TABLE>
they are trying to help. dont be a dick.
if you have enough common sense, do what i did.
use a tow strap and strap the motor to something solid. see: tree.
jump the starter. battery works.
boom. you can do a compression test.
or just do a leakdown. doesnt matter if its in or out of the car.
Re: How to tell if a motor is blown!? (.john)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .john »</TD></TR><TR><TD CLASS="quote">they are trying to help. dont be a dick.
or just do a leakdown. doesnt matter if its in or out of the car. </TD></TR></TABLE>
How do i bolt the starter to the motor if the tranny is not attatched and there is no flywheel attached?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev »</TD></TR><TR><TD CLASS="quote">How do i bolt the starter to the motor if the tranny is not attatched and there is no flywheel attached?</TD></TR></TABLE>
OH yea.. Uhhhhhh.. Thats a good question.
you never said that.
well, it's not our fault you neglected to mention that.
Re: How to tell if a motor is blown!? (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord »</TD></TR><TR><TD CLASS="quote">Open her up.</TD></TR></TABLE>
and look for what
and look for what
look for metal parts that shouldnt be there like part of a valve, dings in the piston or cylinder walls, or maybe a broken rod.
Re: How to tell if a motor is blown!? (crawlin)
damn...Im getting an LS this weekend, and was going to ask the same damn question on how the hell you people get motors off of others.
To me its too much of a hassel to pull head and crap off a motor that "was running".
Now that you are satisfied. Now might as well get a new Head-gasket, timing belt, head bolts, and a damn water pump. Oh and not to forget valve-cover and oil pan gasket and junk. Thats if the seller happens to have an engine stand....
I myself got screwed a few times....especially with trannies. ****
Location: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Re: How to tell if a motor is blown!? (pho^k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .john »</TD></TR><TR><TD CLASS="quote">its simple. DO A LEAKDOWN TEST. </TD></TR></TABLE>
you heard the man
you heard the man
Re: How to tell if a motor is blown!? (kevmugen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevmugen »</TD></TR><TR><TD CLASS="quote">Pull the head and pull the oil pan </TD></TR></TABLE>
Best advice in the thread short of buying a working motor.
Re: How to tell if a motor is blown!? (LowSlow93Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowSlow93Sol »</TD></TR><TR><TD CLASS="quote">Best advice in the thread short of buying a working motor. </TD></TR></TABLE>
Ill do that, What do i need to look for. Otherwise ill just be staring at it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawlin »</TD></TR><TR><TD CLASS="quote">look for metal parts that shouldnt be there like part of a valve, dings in the piston or cylinder walls, or maybe a broken rod.</TD></TR></TABLE>
Right, but how would i know if it had Rod knock, piston slap, or something fucked up in the crank.
