Idling problem
Old Apr 18, 2005 | 05:30 PM
UNKNOWN_MEMBER's Avatar
Default Idling problem
Everything use to be cool untill 1 morning I started my car and it didn't want to idle. I would have to give it gas for literally 2minutes or so. If I was to let it go it would just die. When the motor is warm and i'm driving and get out of gear or push the clutch in it will idle at 1500 untill I come to a stop then just idle real low like 500-600 rpm, sometimes it'll die. What can cause this problem?
Old Apr 18, 2005 | 06:54 PM
Already cleaned the IACV still does it.
Old Apr 19, 2005 | 04:36 AM
JimBlake's Avatar
Default Re: (UNKNOWN_MEMBER)
If you're talking about your '91, then try cleaning your FITV, too. Then maybe check your base idle.
Old Apr 19, 2005 | 07:41 PM
Old Apr 20, 2005 | 12:36 AM
Manifold i'm using doesn't have FITV also.
Old Apr 20, 2005 | 03:16 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">Manifold i'm using doesn't have FITV also.</TD></TR></TABLE>I guess that explains the stalling when it's cold, since the FITV's job is to raise the idle for a minute or 2 while it's cold. Your '91 ECU & IACV are probably programmed to work together with an FITV.
But that doesn't explain the low idle & stalling after it's warmed up. That part sounds like your AICV & base idle. You've already cleaned your IACV, so I guess the next thing is to adjust the base idle.
BTW, how old are your spark plugs, wires, cap, & rotor?
Old Apr 20, 2005 | 01:47 PM
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I guess that explains the stalling when it's cold, since the FITV's job is to raise the idle for a minute or 2 while it's cold. Your '91 ECU & IACV are probably programmed to work together with an FITV.
</TD></TR></TABLE> i'm using a chipped p28 ecu. If I adjust the base idle to go higher, when I get out of gear it would rev to like 2k rpm and then drop down when I stop. What can cause the rpm to raise and then drop down when the car isn't rolling?
Old Apr 21, 2005 | 03:21 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote"> i'm using a chipped p28 ecu...</TD></TR></TABLE>Then I'm not real sure what to do. By 'base idle', I was referring to unplugging the IACV & adjusting idle to 450. The IACV needs to be in the right part of it's control range during operating conditions when it's controlling your idle to 800 or whatever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">... when I get out of gear it would rev to like 2k rpm and then drop down when I stop. What can cause the rpm to raise and then drop down when the car isn't rolling? </TD></TR></TABLE>I thought for some models/years, the ECU looks at the VSS & holds a higher idle while the car's moving. I think it's something to do with avoiding overly-rich conditions during over-run. Your ECU is chipped, so ???? Must be someone around here who knows more about that system than I do.
Old Apr 21, 2005 | 09:32 PM
So does this happen to everyone else that uses p28?
Shmolie
Jun 29, 2005 05:58 PM
UNKNOWN_MEMBER
Apr 20, 2005 12:39 AM
giff74
Mar 15, 2004 10:58 AM
TheIntegraGuy
Jan 22, 2004 06:48 PM
quik2kSi
Dec 27, 2003 09:04 AM
