idle problem
Old Sep 10, 2005 | 07:16 PM
BACKWOODSTEG's Avatar
Default idle problem
hey guys, i got a 94 ls and when in park it would rev. between 1500 and 2000rpm. do you have any idea what would cause this to happen?
maybe a bad sensor?
Old Sep 10, 2005 | 07:24 PM
DAguyLS's Avatar
search IACV (idle air control valve)
Old Sep 10, 2005 | 07:47 PM
98b18black's Avatar
Default Re: (DAguyLS)
fast idle valve...
Old Sep 10, 2005 | 07:54 PM
DAguyLS's Avatar
check for vac leaks also, they would cause a fluctuating idle also
Old Sep 10, 2005 | 08:11 PM
Lauj87's Avatar
could be TPS also.
Old Sep 10, 2005 | 10:08 PM
Greddy Dantegra's Avatar
Default Re: idle problem (BACKWOODSTEG)
i got the same problem... i use seafoam to get all that carbon buildup in my cat out the way after that i used a can of WD-40 and a roll of paper towels to clean all the dirt out from the the throttle body! the idle is alot better and the throttle is more response... give it a try it wont hurt!
protopro88
Apr 8, 2011 03:41 PM
PWRDbyHseries
Oct 18, 2006 05:44 PM
gutted-dx
Dec 18, 2005 09:08 PM
94SHOWLS
Feb 17, 2005 12:31 PM
CRX-SIR
Sep 20, 2004 06:00 PM
