B18b1 idle problem
Old Feb 9, 2014 | 09:39 AM
Jdm_Ej8_Sedan's Avatar
Default B18b1 idle problem
I have a 1995 b18b1 and have been fighting this idle issue for awhile, probably like 4 months now and I cant figure it out.
What it does is when I start it, it idles at like 2k rpm for about 5 min. then starts to fluctuate between 1300-1800 for awhile then when it is 100% warm it will hold steady at about 1300rpm.
I have replaced intake manifold gasket, tps sensor, new pcv valve, screwed in idle adjusting screw, bleed coolant, replaced iacv, adjusted throttle cable, checked for vacuum leaks(none) screwed in wax piece on fitv while on the car.
The only thing I haven't done s take off the fitv to clean.
should I just replace this part or look for something else?
Any input is appreciated, thanks.
Old Feb 10, 2014 | 09:08 AM
b20vteg757's Avatar
Has your car been tuned? If so I would say its a bad tune. Need to adjust ignition timing/fuel mixture at idle to get it right
Old Feb 12, 2014 | 10:36 AM
Default Re: B18b1 idle problem
it has not but i would bet my timing is off, also i have a cel for no oxygen sensor but i dont think it would make the car idle like it does?
Old Feb 13, 2014 | 03:06 AM
b20vteg757's Avatar
Actually your oxygen sensor can affect idle. Take it to someone that knows how or do some research and set your ignition timing at idle also
Old Feb 20, 2014 | 12:02 PM
Mr.Hits's Avatar
I have a b16 with the same issue, except sometimes mine idles like it has a cam. Did you ever get it fixed?
Old Feb 20, 2014 | 07:40 PM
saigonsson's Avatar
Did you run a compression test?
Old Feb 25, 2014 | 12:49 PM
I have not, it has gotten better though, it will only fluctuate when the car is cold, as soon as it starts to warm up, ex: 1/4 warm, the idle smooths out and stops fluctuating until its cold again, I cant figure it out.
Old Feb 25, 2014 | 12:51 PM
no, should I? I don't know if ill get good numbers as my piston rings are burnt from nitrous (I know not smart) I never drive it hard anymore, only like a normal car
Old Feb 26, 2014 | 09:13 AM
saigonsson's Avatar
Couldn't hurt,
Plus 1 on the O2 sensor though.
followthadollar
Apr 20, 2010 06:23 PM
hondachris1994
Mar 3, 2006 06:49 AM
hondachris1994
10
Feb 25, 2006 02:37 PM
94SHOWLS
Feb 17, 2005 12:31 PM
TurboCRVTEC
Oct 9, 2002 05:38 AM
