How do i test a switch
Old Jul 8, 2003 | 04:58 PM
Denny's Avatar
Default How do i test a switch
im having a problem with my jdm fog light switch. i dont know why its not turning on, is there a way to check if the switch is working?
Old Jul 8, 2003 | 05:14 PM
acuracing's Avatar
Default Re: How do i test a switch (Denny)
Hook up a voltmeter and see if there is current going through would be my guess.
Old Jul 8, 2003 | 05:59 PM
Denny's Avatar
Default Re: How do i test a switch (acuracing)
can anybody in socal help me out?
Old Jul 8, 2003 | 06:09 PM
B U N M A N G O's Avatar
try an ohmmeter?
Old Jul 8, 2003 | 07:44 PM
sleeper4dr's Avatar
check for resistance using a volt/ohm-meter.
put each of your 2 leads into the wires that run to the switch or into the back of the switch where the wires are most likely soldered, etc.
flip the switch one way or the other and see what the meter tells you. whether it has 3 wires or 2 just alternate with your leads and flip the switch back and forth and see what your readings tell you.
basically ZERO resistance would tell you that the switch is working while INFINITE means it is not.
do not to touch your two leads while doing this as this will give you false readings.
hth, J
Old Jul 8, 2003 | 08:14 PM
Denny's Avatar
Default Re: How do i test a switch (sleeper4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper4dr &raquo;</TD></TR><TR><TD CLASS="quote">check for resistance using a volt/ohm-meter.
hth, J</TD></TR></TABLE>
sorry im a noob at electrical stuff. i have this thing. is this a volt meter? if so what setting do i put it on? were do i put the red ang black thing?
Old Jul 8, 2003 | 08:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Denny &raquo;</TD></TR><TR><TD CLASS="quote">
you want to piont it at one of the omega ones (omega stands for ohm)... hrmm mebbe I'll just come down tomorrow and help you out I gotta go to Tustin Lexus for the 1k mi checkup on our GS anyway.
Old Jul 8, 2003 | 09:31 PM
Denny's Avatar
Default Re: How do i test a switch (B U N M A N G O)
koo sounds good
hust1er
Audio / Security / Video
Aug 22, 2007 11:21 AM
JDM_d15b_eg8
Dec 26, 2006 05:17 AM
SigmaOmega
Jul 17, 2005 06:55 PM
Mini-mEK4
Oct 19, 2004 01:25 PM
5 watt
Jul 5, 2002 12:07 PM
