help-fuel cutoff switch problem
Old Oct 17, 2004 | 12:07 PM
Mini-mEK4's Avatar
Default help-fuel cutoff switch problem
hey i decided to do a fuel cutoff switch yesterday and i got it all wired up and tried it out. everytime i turn the switch off and then back on it blows a fuse. can someone tell me whats goin on.
Old Oct 17, 2004 | 12:15 PM
EK k kay's Avatar
Default Re: help-fuel cutoff switch problem (Mini-mEK4)
Make sure you have the right kind of switch. I think it was a 25A switch that you should use. Also make sure your wires aren't shorting out where you cut it.
Old Oct 17, 2004 | 12:24 PM
Mini-mEK4's Avatar
Default Re: help-fuel cutoff switch problem (chowmien)
i used a 25A switch from radioshack, im gunna try and solder my connections instead of those tap splices.
Old Oct 17, 2004 | 12:52 PM
GuitarSlinger78's Avatar
I just did this too with no probs. Yeah you have the right switch. I taped up my slices in black electrical tape after I did it. I didn't solder them though on the switch. I wrapped them around really tight about 7 times. But with 18 gauge wire, they aren't going to move. Also taped them really tight too.. good luck its a nice thing to have.
Old Oct 17, 2004 | 02:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: help-fuel cutoff switch problem (JoE94Integ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoE94Integ &raquo;</TD></TR><TR><TD CLASS="quote">I just did this too with no probs. Yeah you have the right switch. I taped up my slices in black electrical tape after I did it. I didn't solder them though on the switch. I wrapped them around really tight about 7 times. But with 18 gauge wire, they aren't going to move. Also taped them really tight too.. good luck its a nice thing to have.</TD></TR></TABLE> No problem yet, the only way not to have a problem is to solder the connections,[all of them] and use shrink tube to insulate the connection. 94
Old Oct 17, 2004 | 05:05 PM
SwiftTone's Avatar
Default Re: help-fuel cutoff switch problem (fcm)
I dont remember what kind of switch i used, but the first time i did it it blew the fuse. after i replaced it, it didnt blow again
Old Oct 19, 2004 | 01:25 PM
JamesQ's Avatar
Default Re: help-fuel cutoff switch problem (SwiftTone)
wrap up all open connections and loose wires.
thundernoodle
Audio / Security / Video
15
Aug 6, 2010 06:05 AM
eL_cArLos
Feb 20, 2008 06:19 PM
JDM_d15b_eg8
Dec 26, 2006 05:17 AM
Denny
Jul 8, 2003 09:31 PM
