?? how to remove pins from 99 si harness??
Old Jul 5, 2003 | 08:14 PM
si1999's Avatar
Default ?? how to remove pins from 99 si harness??
i am putting a p73 into a 99si. i know that i have to move a16 to a15. i just need to know how to get the pins out of the wiring harness.
Old Jul 5, 2003 | 10:36 PM
salbaje's Avatar
Default Re: ?? how to remove pins from 99 si harness?? (si1999)
why not just cut it and add a pin?? You can buy a screwdriver kit for glasses and poke in there and pull the pin out
Old Jul 8, 2003 | 12:08 PM
si1999's Avatar
Default Re: ?? how to remove pins from 99 si harness?? (salbaje)
thx
Old Jul 8, 2003 | 04:41 PM
bigTom's Avatar
the 99-up plugs have the easiest pins to take out... on the pin... say u have the blue one in hand... there is a white plastic piece on it that looks as if it could pop out... its pops out a couple mm's... then play with the pin... i forgot from which side of the plug but use a pick to unclip it and it should come right out... if it isnt coming out easy... ur doing it wrong
Old Jul 8, 2003 | 09:39 PM
3rdGteg's Avatar
Default Re: ?? how to remove pins from 99 si harness?? (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">the 99-up plugs have the easiest pins to take out... on the pin... say u have the blue one in hand... there is a white plastic piece on it that looks as if it could pop out... its pops out a couple mm's... then play with the pin... i forgot from which side of the plug but use a pick to unclip it and it should come right out... if it isnt coming out easy... ur doing it wrong</TD></TR></TABLE>Yeah, exactly what he said.......just did it a few hours ago at work also....
aeon
Jun 16, 2011 12:51 AM
gnd101
Jun 1, 2009 04:44 AM
Touge Tuning
Dec 8, 2005 12:20 PM
Drew96EJ
Sep 27, 2003 03:20 PM
typer 00-115
Audio / Security / Video
Feb 28, 2003 05:38 PM
