Lighting HID/Xenon kits, Retrofits and Associated Topics
dc5 type r 2002 bulb
Old Nov 5, 2011 | 06:18 AM
white_horse's Avatar
Default dc5 type r 2002 bulb
im looking for an hid kit for the 2002 dc5 type r.. may i know what is the socket size for the low beam.. is it h1 or h2 or h4? how about the high beam?
Old Nov 6, 2011 | 06:08 AM
Joon Joon's Avatar
Default Re: dc5 type r 2002 bulb
is it real dc5 headlights? if so then they use hids i believe and they are d2r.. if they are stock usdm headlights then its 9006
Old Nov 17, 2011 | 02:46 AM
i got the original headlight but one side is damaged.. im replacing it w/ a (copy) jdm itr headlight non hid...
question is can i still use the oem hid kit that comes w/ the original headlight?
Old Nov 17, 2011 | 08:11 AM
Joon Joon's Avatar
if the light is non hid then no.. itll most likely be 9006 not d2r
Old Nov 17, 2011 | 01:45 PM
will the sockets from a orginal hid headlight be compatible w/ the new non hid headlight? or do i need to do some splicing for the wire to accommodate the 9006 bulbs? actually what is a 9006 bulb? is it different from an h1 or h4?
Old Nov 17, 2011 | 03:11 PM
Joon Joon's Avatar
sorry I thought the stock bulb was 9006 but youre right its h1.. so the aftermarket will be h1 not d2r how did you wire the hid versions?
Old Nov 18, 2011 | 02:30 AM
actually the hid version was just plug n play to the oem ballast.. im wondering if i get a replacement which is a non hid headlight, how can i connect the non hid bulb to the stock harness? is it also plug n play or do i need some modification? ** the car is a authentic jdm itr dc5 2002
Old Nov 18, 2011 | 06:35 AM
Joon Joon's Avatar
i see.. i would try to get oem headlights.. reason being, the focal point will be off and the glare will be increased.. i wouldnt really recommend it..
if you still decide to go that route, here is an adaptor you could use to hook up your oem ballast to an aftermarket hid h1 bulb.. http://www.theretrofitsource.com/pro...roducts_id=244
Old Nov 18, 2011 | 06:34 PM
about replacing the oem hid bulb.. i cant find any sockets from the bulb to the oem ballast. its like the whole thing is soldered.. how can i replace the bulb?
Old Nov 18, 2011 | 06:42 PM
m_shake's Avatar
One oem one knock off........ghetto.
Old Nov 18, 2011 | 07:36 PM
Joon Joon's Avatar
ignitor looks something like this.. it connects to the bulb..
the d2r bulb end looks like this..
together it looks something like this
just twist the ignitor counter clockwise and pull it off the bulb..
Old Nov 19, 2011 | 02:33 PM
i think the oem has its own igniter.. can i use it? or the oem bulb is permanently connected to the igniter?
Old Nov 19, 2011 | 03:43 PM
Joon Joon's Avatar
yes the oem should have its own ignitor.. twist the ignitor counter clockwise then pull it off the bulb..
Old Nov 20, 2011 | 01:38 AM
oh yeah! thats good news! il just need some new bulbs! any d2r bulb will do right?
Old Nov 20, 2011 | 06:19 AM
Joon Joon's Avatar
i suggest oem not aftermarket.. osram, philips, ge.. are you still getting an aftermarket headlight? again the cutoff isnt going to be the same as the oem hid version
Old Nov 21, 2011 | 02:49 AM
i got no choice but to get new bulbs.. the other is busted.. a frend is offering me a new kit of d2r bulbs w/ ballast (aftermarket) i forgot the brand but its not philips. il have to postpone on getting a new headlight and stick with the original... shall i go for the new kit or just look for some new bulbs only?
Old Nov 21, 2011 | 03:57 AM
by next year im ordering from the states headlights that came from acura rsx 2002 is it compatible w/ the jdm itr dc5 2002 body?
Old Nov 21, 2011 | 06:15 AM
Joon Joon's Avatar
i would go with just new oem bulbs.. as far as the rsx, yes they are the same but not hid.. what is wrong with the ones you have now? you said they were broken?
Old Nov 22, 2011 | 07:59 PM
well the one headlight got messed up when i bought the car it was sanded but the finish was hazy. so i got a blured headlight.. then the oem bulb busted maybe its really old.. its hard in here to get oem d2r (in the philippines), quite expensive! i was offered a xenon d2r hid kit.. will it do?
Old Nov 22, 2011 | 08:12 PM
can u give me a link or pic of an aftermarket d2r hid kit i will try to compare it..
Old Nov 22, 2011 | 09:39 PM
Joon Joon's Avatar
the haze could still be buffed out..
hit up theretrofitsource.com.. give them a call or email and they could set you up with some d2r bulbs..
Old Nov 23, 2011 | 04:31 AM
the headlight was wet sanded and a clear coat was applied to it.. unfortunately when the headlight heated up it caused the clear coat to form a permanent haze... im planning to wet sand it again to remove the layer of clear coat and re do the whole thing though..
Old Nov 23, 2011 | 05:43 AM
Joon Joon's Avatar
yeah wetsand it down until you get the clear off then buff it out.. since its just the lens thats messed up, find some broken dc2/rsx headlights with good lenses then just switch them out... you dont need the rear housing to be good since the ones on your car are good.. just heat up the housings to get the lenses off..
Old Nov 23, 2011 | 01:57 PM
will the headlight not crack if i heat the seal and swap it?
Old Nov 23, 2011 | 02:24 PM
Joon Joon's Avatar
no I do it all the time to do retros
