Help w/ CEL Code 22...VTEC Oil Pressure Circuit...
Old Jul 12, 2002 | 02:09 PM
BeeResp0nsible's Avatar
Community Builder
Community Influencer
Default Help w/ CEL Code 22...VTEC Oil Pressure Circuit...
I have a code 22 showing up on my CEL, and I dont know what to do?! I changed my oil today, and still nothing...What else could be wrong, and how much is it going to cost for me to fix it??? Thanks!
Old Jul 12, 2002 | 02:49 PM
91DA9's Avatar
Default Re: Help w/ CEL Code 22...VTEC Oil Pressure Circuit... (Integrakid2002)
Firs things first. Have you checked your oil?
Is your oil pressure light on? Check the two connections on the VTEC assembly, the solenoid, and the pressure switch.
Old Jul 12, 2002 | 07:17 PM
Community Builder
Default Re: Help w/ CEL Code 22...VTEC Oil Pressure Circuit... (94IntegraGSR-OVR)
How can I go about checking the solenoid, and the pressure switch???
Old Sep 11, 2002 | 05:56 AM
2qwik2nv's Avatar
Bump, I'm also getting this error, please help!
Old Nov 28, 2002 | 05:28 PM
Lude2nv's Avatar
Default Re: Help w/ CEL Code 22...VTEC Oil Pressure Circuit... (2qwik2nv)
Check your oil pan, see if it is dented? You will need to pound it out or get a new one. Dent will slow the rate of oil going into your engine. thus making your vtec not to work. It happened to mine. My vtec would only work when the car first warmed, for about three minutes. The check engine light would only come on when rpms where in the specified range of the vtec.
Old Nov 28, 2002 | 07:20 PM
bruthaboost's Avatar
Check continuity of the pressure switch and vtec solenoid as well.
Old Nov 29, 2002 | 05:43 AM
95GSRRacer's Avatar
If the oil is low, it will do the same thing. Check the oil level
94wip
12
Jun 20, 2024 07:23 PM
missionaryrider
Dec 9, 2007 01:50 AM
drudy
Aug 26, 2005 12:20 PM
WhatThaFrig
Oct 11, 2004 12:14 PM
FusionITR
Sep 20, 2002 12:46 PM
