CEL Code #22
Old Sep 8, 2002 | 03:13 PM
FusionITR's Avatar
Default CEL Code #22
22 92-98 Civic
93-98 Prelude
94+ Integra VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
* invalid code for non-VTEC engine
ok this is the cel i got.... so how do i go about fixing this?
Old Sep 8, 2002 | 03:56 PM
FusionITR's Avatar
Default Re: CEL Code #22 (FusionITR)
top
Old Sep 8, 2002 | 06:16 PM
FusionITR's Avatar
ttt
Old Sep 8, 2002 | 06:40 PM
uNF$@#!'s Avatar
check your oil level first
Old Sep 8, 2002 | 09:38 PM
FusionITR's Avatar
Default Re: CEL Code #22 (Soup ****)
my oil level is fine
Old Sep 11, 2002 | 05:05 AM
2qwik2nv's Avatar
I'm getting the same cel code, my oil level is ok as well. Help Please!!
Old Sep 11, 2002 | 06:24 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: CEL Code #22 (2qwik2nv)
Clean the Vtec solenoid.
Old Sep 11, 2002 | 06:31 AM
Dave-ROR's Avatar
does it come back after resetting the ECU? we had this once on a friends 97 R but it hasn't come back since reseting the ECU. otherwise, follow the diags, check vtec sol, check oil pressure switch, ecm.
Old Sep 20, 2002 | 12:04 PM
typer_801's Avatar
Default Re: CEL Code #22 (Apex i ITR)
Could you please explain how or more specifically what to clean? I've already removed the pre-screen it's clean, checked connections, oil level, etc.
Old Sep 20, 2002 | 12:11 PM
Michael Delaney's Avatar
Default Re: CEL Code #22 (typer_801)
there's a filter basket when you remove the VTEC solenoid from the engine. It gets clogged sometimes and prevents the oil pressure to build up to trigger the pressure switch. It's the first thing you do as an easy quickfix (if that is indeed the problem).
the helms manual diagnostic check list for that code will help you here. You check the connectors and also check if the oil pressure reads correctly at specific rpms briefly while the engine is not loaded.
Old Sep 20, 2002 | 12:46 PM
Apex i ITR's Avatar
Default Re: CEL Code #22 (Michael Delaney)
Do you have a V-AFC. Steve Sakai has experienced a lot of problems with them and he swears the v-AFC's are problematic (Even though I haven't had this problem.......yet).
Of course if you don't have a v-Afc then I'd have to rethink what else it could be.
Boots
Jan 5, 2007 09:35 PM
SKDRCR
May 30, 2006 11:44 AM
96tegsr
Aug 12, 2003 08:53 AM
BeeResp0nsible
Nov 29, 2002 05:43 AM
