Help!Shifting problem
Old Oct 27, 2002 | 11:57 AM
TeAm IllUsIonZ978's Avatar
Default Help!Shifting problem
Alrite i have a shifting problem it all started yesterday after the car show in providence RI ,when i was leaving the car show i couldn't shift in 1,5,or reverse well i made it home diving on 4th all the way home but the today i went to see wat was wrong with it at first i thought the short shifter might on effected that but i check and made sure it was tightthat was okay,then filled some fluid in im because there a really slow leak .. then startd it up and all gears will work but reverse still doesn't work.And also then when it in gear the shifter can still be moved side to side like its in nuetral?HELP me asap... thanks
Old Oct 27, 2002 | 12:20 PM
Default Re: Help!Shifting problem (TeAm IllUsIonZ978)
help some one
Old Oct 27, 2002 | 12:44 PM
Clucth master cylinder ? weres the located?
Old Oct 27, 2002 | 07:29 PM
976's Avatar
976
New User
Default Re: Help!Shifting problem (DOHC_VTEC)
Bleed your clutch, through slave cylinder. Search, you will find exact directions. If you slap in 2nd before you drive it helps align the gears. Might help. Bleed that bitch, you'll be fine. Honda 3.1 brake fluid is a good choice, or Motul, or ATE. Nothing else.
Old Oct 27, 2002 | 09:39 PM
SpdNvy's Avatar
I had the same prob with my '92 lude. The Master cylinder and maybe also your Slave is out, or going out.
If your leaking that may also be a sign of a bad Slave cylinder
Old Oct 28, 2002 | 03:27 AM
Default Re: Help!Shifting problem (SpdNvy)
I heard that it might be the sycros damaged...It is caused by the short shifter, the sycros line up perfect with the stock shifter and and short shifter give . of a second quicker it doesn't line up. Question is does any one have any ideas how repair it and able to keep the quick throw(with out damaging the sycros agian).
Old Oct 28, 2002 | 04:42 PM
GripFactoR's Avatar
sounds like a clutch/tranny issue to me.
Old Oct 28, 2002 | 08:12 PM
3rdGteg's Avatar
Default Re: Help!Shifting problem (VTECxSiR)
Before throwing out cash, lift ur car up and go underneith and look at ur shifter where it is bolted to the shifter rod--the bolt may have came loose. Mine was too loose and I can wiggle my shifter left to right about a whole inch while in gear; tightened the bolt and it was cool. ALso I'd take care of that leak asap.
leeant
Transmission & Drivetrain
Jul 26, 2016 04:37 PM
Djole_V
Feb 12, 2008 10:12 AM
Kamikaze
Jul 1, 2007 07:21 PM
Akalima
Sep 17, 2005 10:11 PM
silvr92lude
Jan 30, 2005 04:04 PM
