Transmision problem
Old Sep 17, 2005 | 07:31 PM
Akalima's Avatar
Default Transmision problem
Ok i went out drag racing today for the first time. Did my first pull and felt like i was breaking loose all the way down the track. I was goin for another run and started my car and could not get it in gear. the same thing happend 3 weeks ago changed fluid and master cylinder. Problem went away. This time it didnt i put the car in gear and then started the car and was able to shift OK. The shifting got worse as i drove home to the point where the clutch is not dissengaging now. But when car is off and clutch is in i can shift through the gears. The clutch i have in there is supposed to be indestructable(i have 300 wheel horse) I was told it could be the slave cylinder and the clutch fork? Please help advice would be greatly appreciated as im gonna put the tranny myself. thx
Old Sep 17, 2005 | 07:56 PM
b18bEKcoupe's Avatar
Default Re: Transmision problem (Akalima)
The slave cylinder is most likely leaking. Check your fluid level in the master cylinder and see if you can see any fluid around the slave cylinder.
Old Sep 17, 2005 | 10:11 PM
Akalima's Avatar
Default Re: Transmision problem (b18bEKcoupe)
the fluid is a little low but its not under the add line last i checked but if the slave is leaking would it also be sucking in air ?
sipolt89
Dec 10, 2008 02:34 PM
Honduh Uhcord
Oct 15, 2007 08:29 PM
PearlBlueType-S
20
Mar 6, 2006 11:10 PM
Peasonrice
May 5, 2005 04:17 PM
95civicracer
Aug 3, 2003 04:58 PM
