Help with my D16 build ...
Old Mar 14, 2003 | 10:54 PM
senpai's Avatar
Default Help with my D16 build ...
I want to try and do piston/rod install WITH the block still in the car. I am still going to take my time, but I didn't want to pull it out. For simplicity sake, let's say my bores are not out-of-round or tapered too much. (I am waiting for my bore gauge from eBay to arrive.) Now I have questions:
- There is still coolant in the block around the sleeves (is that called the water jackets?) Anyways, does that drain if I pull the drain plug on the block?
- There are no visible scratches. I can run my finger inside all the bores and there are no scratched of any kind except for the cross hatch marks; they look very good BTW. Should I re-hone it?
- When I hone it, what am I looking at to cover up? Should I take the crank out? or Can I just place plastic over it? How about around the sleeves?
[Modified by maztur, 1:55 AM 3/15/2003]
Old Mar 15, 2003 | 09:20 AM
crx(gator)'s Avatar
Default Re: Help with my D16 build ... (maztur)
why do you have a problem with removing the actual engine, it will be 10000x easier to install pistons and rods with the engine out...
Old Mar 15, 2003 | 01:55 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
no kiddin, my friend and I pulled his D15 out in about 3 hours, and neither of us had done it before. Since you obviously already have the head off, it should be even easier for you.
Old Mar 15, 2003 | 02:04 PM
dfoxengr's Avatar
Default Re: Help with my D16 build ... (PatrickGSR94)
to change rods and pistons you need to take the oil pan and all that **** out...
dfoxengr's Avatar
Default Re: Help with my D16 build ... (hybridvteceg)
cant do it from the top of the block..lift it up and try your luck....
ek9tl
May 11, 2007 02:50 PM
93c1sol
Mar 6, 2006 01:15 PM
fknfast
Jan 23, 2004 09:47 AM
Aeka GSR
Sep 19, 2003 11:53 PM
baphomet
Feb 2, 2003 09:25 AM
