Help with compression tests results. Please respond!!!
Old Jun 20, 2007 | 10:21 AM
  #51
Flashmn's Avatar
Default Re: (chump2825)
sounds like the "mechanic" he get his answers from probably is just another kid that does work on cars. I mean if he was a real mechanic he wouldnt be making these statements.
As for the oil light coming on, it only comes on if you lose pressure below a certain limit. It might come on if theres low oil level and the pump sucks in air, however you might not even see it.
Old Jun 20, 2007 | 04:16 PM
  #52
HAMOTORSPORTS's Avatar
This is absurd. You bought the car. You got to test drive and you paid for the car as is. If something happened to it after you bought it sorry about your luck and leave the dealer alone.
Old Jun 20, 2007 | 06:51 PM
  #53
chump2825's Avatar
nah mech knows how to work on cars
oil light never was on
hamotorsprtsusa did i ask what you thought no?
i still says 190 compression on a itr is bad
did a compression test on a gsr it had 220
Old Jun 20, 2007 | 06:54 PM
  #54
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chump2825 &raquo;</TD></TR><TR><TD CLASS="quote">nah mech knows how to work on cars
do you realize compression test numbers will differ based on the actual tester being used, elevation, how many times you crank the engine, how the actual test is performed? how many times do people have to tell you as long as the numbers are within 10psi of each other they're ok?
you are one ignorant SOB
Old Jun 20, 2007 | 07:12 PM
  #55
monEmakindave's Avatar
Default Re: (doood)
so i guess your boy with the gsr is gonna need a rebuild too. 220 is not 260
like you say it should be. was it 220 across the board?
I don't know how many times you have to read 190 190 210 210 are ok
Its the percent difference that is used to determine if the motor is good or not!
Old Jun 20, 2007 | 07:21 PM
  #56
doood's Avatar
Default Re: (monEmakindave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monEmakindave &raquo;</TD></TR><TR><TD CLASS="quote">so i guess your boy with the gsr is gonna need a rebuild too. 220 is not 260
Its the percent difference that is used to determine if the motor is good or not!</TD></TR></TABLE>
just forget it. this guy obviously know's more than everybody else and will only believe what he wants. even if the evidence is ******* him in the ***.
Old Jun 20, 2007 | 07:36 PM
  #57
Default Re: (doood)
time and time again I have backed myself with the proper info to prove my point with explanations.
His threory is what he still insists to go by.
We can argue till were blue I guess this is a no win situation and things are just better left alone.
Old Jun 20, 2007 | 08:00 PM
  #58
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chump2825 &raquo;</TD></TR><TR><TD CLASS="quote">hamotorsprtsusa did i ask what you thought no?
You are on a public forum, crackhead...
If you don't want comments, then take it back to the Myspace and IM bullsh*t...
Someone please close this thread or move it!
This has become a personal beef peppered with buyer's remorse; I don't see the "tech" apparent anywhere...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monEmakindave &raquo;</TD></TR><TR><TD CLASS="quote"> I guess this is a no win situation and things are just better left alone.
on h-t, in the state this thread is currently in, you are correct...
slammedbbs
May 9, 2011 04:14 AM
LStegMATT
Jan 14, 2008 05:33 PM
dbiker207
Nov 26, 2006 07:10 AM
spankey167
13
Sep 23, 2004 05:30 PM
projektCRX
Apr 22, 2004 12:18 PM
