compression test results???? b81b1
Old Apr 21, 2004 | 12:48 AM
projektCRX's Avatar
Default compression test results???? b81b1
I just used a compression test kit from shucks.
testing for b81b1 obd1
in descending order....
4 - 150psi
3 - 150psi
2 - 150psi
1 - 151psi
they all seem constant. but is that or ??? any replies would help!!!
Old Apr 21, 2004 | 01:01 AM
projektCRX's Avatar
Default Re: compression test results???? b81b1 (projektCRX)
oh and yah i didnt keep the throttle open, and it was about 5 cranks. before i stopped.
Old Apr 21, 2004 | 01:52 AM
civickiller's Avatar
thats good, as long as they are really close, and 150 sounds good
Old Apr 21, 2004 | 02:37 AM
skyripper's Avatar
Default Re: compression test results???? b81b1 (civickiller)
standard is 199 psi, and the minimum acceptable pressure is 135 psi. (from my haynes book)
Old Apr 21, 2004 | 03:42 AM
Maintenance's Avatar
Default Re: compression test results???? b81b1 (skyripper)
That sounds about right. I did a compression test on my sister's b18b1 motor it came to about 170 for all 4 cylinder. This is with 110,xxx miles on it.
Old Apr 22, 2004 | 12:18 PM
projektCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">thats good, as long as they are really close, and 150 sounds good</TD></TR></TABLE>
cool, thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skyripper &raquo;</TD></TR><TR><TD CLASS="quote">standard is 199 psi, and the minimum acceptable pressure is 135 psi. (from my haynes book) </TD></TR></TABLE>
standard is 199, holy crap.. hmmm reason why i did the test is to see if its ok to turbo??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxfear &raquo;</TD></TR><TR><TD CLASS="quote">That sounds about right. I did a compression test on my sister's b18b1 motor it came to about 170 for all 4 cylinder. This is with 110,xxx miles on it.</TD></TR></TABLE>
i only did 5 cranks i wonder if i kept cranking to see untill the needle stop hoppin... ? if it would be higher..
_______________________________
k so my goal was primarly to prep for turbo, only gonna be boostin like 7
-sum1 suggested i get it dyno tuned before boostin
-should i do it before or after ?? ?
thanks for all ur guys help!!!
boosted k20
Apr 21, 2005 04:55 PM
snowblind7x
Apr 13, 2005 08:12 PM
luckypon7
Mar 16, 2005 08:52 AM
tweekerz
Apr 30, 2004 09:43 AM
ozzyman
Apr 22, 2004 10:12 AM
