compression test question
is there a way to test compression in a cylinder with the engine out of the car? i have a compression tester, will i get an accurate reading by cranking the engine over by hand a few times or will i lose pressure to fast?
i dont think so....never heard of doing a compression test with the motor out...i just did mine...ran 190 across with a b20b4 bottem end...low comp setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mouab18c1 »</TD></TR><TR><TD CLASS="quote">never heard of doing a compression test with the motor out...</TD></TR></TABLE>
me neither
me neither
You wil not be able to do the compression check however you could do a leak down test. Which in all reality would accomplish the same thing. Kind of a static compression test.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">Try it, turn the crank over with an impact gun to build pressure.</TD></TR></TABLE>
i wouldnt do that, you may snap the crank bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808DB1 »</TD></TR><TR><TD CLASS="quote">the motor needs to be at operating tempature </TD></TR></TABLE>
Technically yes, but you can still observe cylinder variability when it is cold. OP, have you considered connecting the starter and "jumping" it?
