abs and brake light problem???
Old Oct 20, 2004 | 09:44 AM
tegon-gsr's Avatar
Default abs and brake light problem???
Im haveing a problem with my abs and my brake light they will sometimes just come on while driving and then turn off sometimes does anyone no what this could be from?
I also have hondata with boost could this be the problem?
Old Oct 20, 2004 | 09:45 AM
Slo Car's Avatar
Default Re: abs and brake light problem??? (tegon-gsr)
how's ur brake fluid level?
Old Oct 20, 2004 | 09:52 AM
tegon-gsr's Avatar
Default Re: abs and brake light problem??? (Slo Car)
there fine to what i could see but would that make the brake light come on and the abs?
Old Oct 20, 2004 | 10:15 AM
Slo Car's Avatar
I've seen it before...if the fluid is low it trips the light....
Old Oct 20, 2004 | 10:22 AM
tegon-gsr's Avatar
ok well im going to put some more in right now i will see if that helps.
Old Oct 20, 2004 | 10:57 AM
JB20VTEC's Avatar
My brake lights comes on when my car is cold and my fluid is fine. dont know what it is?
Old Oct 20, 2004 | 11:26 AM
JimBlake's Avatar
Default Re: abs and brake light problem??? (JB20VTEC)
If the float switch in the brake fluid reservoir is flaky, it triggers the light. Clean it & make sure it *floats*.
That's the same circuit as your handbrake. Look for a little button switch under the handbrake lever. Maybe it's bent or something?
I think the ABS light comes on if you're driving with the handbrake on. But maybe a bad reservoir float switch will make the ABS 'think' that the handbrake is on??
Old Oct 21, 2004 | 12:15 PM
tegon-gsr's Avatar
Default Re: abs and brake light problem??? (JimBlake)
it was the little thing that was not floting thanks guys for helpin me
nismok720
Mar 27, 2011 05:16 AM
gosu08
Nov 11, 2009 02:24 PM
HONDA_TYPE_R
Nov 30, 2004 01:04 PM
sushib01
Aug 30, 2004 03:43 PM
hankd
Aug 14, 2002 04:27 PM
