going boost...ur thoughts
Old Apr 25, 2003 | 03:51 PM
wm5holla's Avatar
Default going boost...ur thoughts
i talk to alot of people who are going turbo or have turbo but they all say its pointless to built ur block.. tell ur thoughts
Old Apr 25, 2003 | 06:14 PM
Quick 200k Mile Motor's Avatar
Default Re: going boost...ur thoughts (wm5holla)
depends on how much boost you're going to run..
Old Apr 25, 2003 | 06:57 PM
Blaze45's Avatar
Brrraaaap!
Default Re: going boost...ur thoughts (Quick 200k Mile Motor)
I member I saw a d16z6 w/ about 16.5 psi.... sure it was stock block.
Blaze
Old Apr 25, 2003 | 08:02 PM
icelarry27's Avatar
Default Re: going boost...ur thoughts (Blaze45)
if you wanna run high boost, build block. if your gonna run stock psi (like around 7), i wouldn't worry about it too much.
Old Apr 26, 2003 | 05:04 AM
wm5holla's Avatar
Default Re: going boost...ur thoughts (icelarry27)
less than 10 psi.i i was thinking about going<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icelarry27 &raquo;</TD></TR><TR><TD CLASS="quote">if you wanna run high boost, build block. if your gonna run stock psi (like around 7), i wouldn't worry about it too much.</TD></TR></TABLE> can some one do the math with this.. sohc vtec 125 hp with 5psi of boost and 10psi.. how much should hp should i have? i just want to see like 200hp.
Old Apr 26, 2003 | 05:30 AM
gitwidit's Avatar
10 psi shoulld get you close to 200, that's about the limit on a stock block if your not tuned. I personally wouldn't run that much on a stock block un-tuned, just my opinion
Old Apr 26, 2003 | 05:37 AM
wm5holla's Avatar
Default Re: going boost...ur thoughts (GITWIDIT)
whats are some good kit for a sohc vtec?
Old Apr 27, 2003 | 01:25 PM
eg6turbo's Avatar
greddy and apexi makes a kit...also JG edelbrock is coming out with a kit too...
i run the greddy and made 200 whp at 10 psi untuned...i have afc hack up and running kinda and will repost the results soon...read the sig for more details
Old Apr 27, 2003 | 06:36 PM
wm5holla's Avatar
Default Re: going boost...ur thoughts (eg6turbo)
but how to find out how much hp a kit will give you!
Old Apr 28, 2003 | 08:24 PM
Draco's Avatar
If you are going to boost your car I would suggest reading Maximum Boost by Corky Bell. It is one of the most complete turbo books and goes over pretty much everthing you need in a turbocharged system.
Old Apr 28, 2003 | 10:39 PM
DIRep972's Avatar
Smarter than you
Dont make things complicated by building a motor unless you have too. Stock motors are perfectly fine for 250-300whp w/ a nice set up and proper tune. Boost is great though it makes making power easy.
Old Apr 30, 2003 | 03:14 AM
wm5holla's Avatar
Default Re: going boost...ur thoughts (IRepD)
a lot people tod me to read Maximum Boost by Corky Bell. i will poly go to B&N to get the book in 2 weeks<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IRepD &raquo;</TD></TR><TR><TD CLASS="quote">Dont make things complicated by building a motor unless you have too. Stock motors are perfectly fine for 250-300whp w/ a nice set up and proper tune. Boost is great though it makes making power easy.</TD></TR></TABLE>i just wantto safe. idont want to blow a motor and spend money twice. i want to do it RIGHT the first time whats price on slugs and rods?
Old Apr 30, 2003 | 03:15 AM
wm5holla's Avatar
Default Re: going boost...ur thoughts (Draco)
http://www.clix.to/holla
Old Apr 30, 2003 | 08:12 AM
raene's Avatar
Default Re: going boost...ur thoughts (Mr. Belding)
You should be able to see 200hp on a stock-block D-series engine at 10psi boost with tuning. That's the key to making reliable power on a stock block! Don't just expect to bolt it on and tear up the streets day in and day out.
Perhaps you shouldn't worry so much about your hp numbers... from what I've seen that D is going to have some very nice tq figures.
Old Apr 30, 2003 | 12:28 PM
wm5holla's Avatar
Default Re: going boost...ur thoughts (raene)
define tuning...
Old Apr 30, 2003 | 01:01 PM
eg6turbo's Avatar
tuning - finding the most power while running the motor safely...this would have to be on the dyno with a wideband and tweaking with certain upgrades u might have...ie: fpr, afc,boost controler, injectors, ecu, spark plug gap, timing....theres lots more..
Old Apr 30, 2003 | 03:07 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6turbo &raquo;</TD></TR><TR><TD CLASS="quote">tuning - finding the most power while running the motor safely...this would have to be on the dyno with a wideband and tweaking with certain upgrades u might have...ie: fpr, afc,boost controler, injectors, ecu, spark plug gap, timing....theres lots more..</TD></TR></TABLE>
or in simple southerner's term: maxmize the engine potential without blowing **** up.
Old Apr 30, 2003 | 03:51 PM
DaveSI99's Avatar
Best thing to do is a block guard, a thicker head gasket and SRP's pistons and your safe up to 16 psi of boost.
Old Apr 30, 2003 | 04:22 PM
t0p_sh0tta's Avatar
Default Re: (DaveSI99@aol.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveSI99@aol.com &raquo;</TD></TR><TR><TD CLASS="quote">Best thing to do is a block guard, a thicker head gasket and SRP's pistons and your safe up to 16 psi of boost.</TD></TR></TABLE>
I've heard that blockguards restict coolant flow. Anybody have any input on this?
Old Apr 30, 2003 | 06:31 PM
wm5holla's Avatar
Default Re: (t0p_sh0tta)
i thinkin about buildin up a b18a with je slugs and eagle rods. i want hi boost
Old Apr 30, 2003 | 06:37 PM
warwagon's Avatar
/quote/I've heard that blockguards restict coolant flow. Anybody have any input on this/quote/ ??????
look at the damn things that should answer your question!!! my rs sleeved block doesnt have any bracing, just my .02
Old May 1, 2003 | 06:21 AM
SIK IN DA HED's Avatar
New User
Old May 1, 2003 | 06:58 AM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Draco &raquo;</TD></TR><TR><TD CLASS="quote">If you are going to boost your car I would suggest reading Maximum Boost by Corky Bell. It is one of the most complete turbo books and goes over pretty much everthing you need in a turbocharged system.</TD></TR></TABLE>
Absolutely
"Turbos make torque. Torque is fun." heh
Old May 1, 2003 | 07:48 AM
wm5holla's Avatar
Default Re: going boost...ur thoughts (Muckman)
whats the price for a power package and who sell them i 4got? pistions and rods...
tonys91tegra
Jul 9, 2009 11:07 AM
97grnrs
Jan 6, 2008 07:07 PM
TEG777
Jul 29, 2005 12:15 PM
Big Bang
Aug 12, 2004 01:38 PM
BlackGSR
Feb 20, 2002 03:04 PM
