Fuel pump problems!!!!
Old May 14, 2013 | 10:54 AM
Jmx305's Avatar
Default Fuel pump problems!!!!
Hey guys I'm having a problem with my fuel pump. The pump is not getting power thus my car is not turning on. I recently swapped a b18c type r with a far tranny I got myself a rywire harness and everything is good. The motor cranks but it won't start. Whenever I got to turn the key my pump doesn't prime. I already check the main relay I actually replaced it with a new the old one for some reason had water in it, I got one from autozone and I checked all my fuses and they're all good. Now if I run a wire from the pump to the battery the pump does kick in and I was able to start the car.... So I really don't know what could be the problem... By the way the car is 93 CIVIC DX HATCHBACK. If you guys can shed some light that would be great. Thanks!!!
Old May 14, 2013 | 11:01 AM
Jmx305's Avatar
Default Re: Fuel pump problems!!!!
**By the way I meant a GSR tranny not a "far" tranny lol
Old May 14, 2013 | 08:27 PM
ThE HeLLRaZoR's Avatar
Read this:
http://www.rywire.com/catalog/images...milspec_eg.jpg
There are like 6 pigtail wires on your new Harness. The Green/Blue wire needs to be spliced in to your old Cabin harness at pin A7(Fuel Pump)
Old May 14, 2013 | 08:37 PM
Also look at this thread from a few days ago...
https://honda-tech.com/forums/engine-management-tuning-124/help-rywire-milspec-harness-2956186/
In the first two pictures, those are the wires we're talking about.
The Green/Blue wire in that bunch needs to be wired to your old ecu plug at location A7.
Old May 15, 2013 | 04:42 AM
Jmx305's Avatar
I did that I even email rywire yet I still got nothing. The only other thing that I think it could be would be my computer which I doubt it could since I also bought from rywire them self. But I'll try using my stock ecu and see what happens. Got any idea what also could it be?
Old May 16, 2013 | 08:12 PM
unspankable's Avatar
figure this out?
Old May 16, 2013 | 08:19 PM
Did you check your grounds on your thermostat housing?
Old May 17, 2013 | 05:41 AM
Jmx305's Avatar
Nah I'm still working on it. I have a ground wire there. Now that you mention that... I do have a ground cable there. The rywire harness came with a ground wire and I connected there. I have another ground coming from the tranny to the car. Am I missing another ground? I've pretty much checked everything else. All my wiring, fuses, and relay are all good. I mean the car was running perfectly before the swap so I just don't know.
Old May 17, 2013 | 06:50 PM
check for corrosion on the grounds. Then your ignition switch.
Just a couple of suggestions
Check this thread too
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/chasebays-cm1-harness-install-eg-%7Bqs%7D-3057100/
Old May 20, 2013 | 07:57 AM
Jmx305's Avatar
All my grounds look fine, but I do need an ignition coil. Would that have anything to do with it? The one that I had is gone.
Old May 20, 2013 | 07:20 PM
GSR FART's Avatar
sounds like the ignition switch
Old May 20, 2013 | 07:22 PM
GSR FART's Avatar
coil is ether good or bad
Old May 21, 2013 | 05:55 PM
Jmx305's Avatar
I just got a new coil and rotor and the car was running fine before the swap. Now I have another question. When I jump the relay and try to start the car, the car cranks but my fans won't turn on. The person who had the before had the fans running the whole time. If I take off the ground the goes from the tranny to the chassi the fans do turn on but the car won't crank... I'm starting to think that my problem has to do with my grounds wires, so far I have three. The batter one, I have one going to my chasi to the tranny and the ground that came with my rywire harness that I hooked up on the thermostat housing. Are my grounds good? Am I missing another ground or what? I checked and tested just about everything. New battery, new main relay, all fuses are good, everything is hooked up probably as far has my harness and all that.
Old May 21, 2013 | 06:26 PM
Jmx305's Avatar
If my ignition switch were to be bad, how would I go about checking it?
Old May 22, 2013 | 05:04 PM
GSR FART's Avatar
check voltage at the relay with ign. on check pump ground
Old May 22, 2013 | 05:15 PM
Jmx305's Avatar
Ok. I'll do that. Any idea why my fan won't turn on with my tranny ground wire is on? Where's the pump's ground? Doesn't it all go to the relay? Another thing just to be thuro my harness has a knock sensor plug but my engine is jdm so it doesn't have a
Knock sensor, would that Prevet the car from starting? I do have a chipped ecu from rywire as well.
Old May 22, 2013 | 05:18 PM
Jmx305's Avatar
*thorough
scspeed
Apr 2, 2009 10:53 PM
nabin
58
Nov 10, 2007 03:24 PM
japan4racing
Sep 18, 2005 06:33 AM
japan4racing
Sep 18, 2005 04:40 AM
gloryhog
Jul 30, 2004 06:14 PM
