fuel pump wont prime,suggestions?
Old Jul 29, 2004 | 06:15 PM
gloryhog's Avatar
Default fuel pump wont prime,suggestions?
Ive already put a main relay in(honda oem). the car will start fine and then today I went to start it and that whirring sound from the pump was not there. pulled the neg. off the battery and replaced after 30 sec. it cranked. now the pump will prime if I leave the key turned over for a while , its the pump I think. Ive got a new holley 255lph coming monday .what do yall think?
Old Jul 30, 2004 | 05:29 PM
gloryhog's Avatar
Default Re: fuel pump wont prime,suggestions? (gloryhog)
somebody chip in!
Old Jul 30, 2004 | 06:14 PM
DXDOHCVTEC's Avatar
Well if you rule ot the M/R then it must be somthing in the wiring. Depending on what Y/M/M you car is I think there are some factory fuel pumps that are self grounding and that could be the problem. A good suggestion would be when you hook up the new fuel pump check out the wires and connections if they look bad that may be the problem. When you wire in the new one do it right so you wont have to do it again. Then test the old one to see if it was just faulty. If it was the car should start.
AZ accord
Sep 10, 2015 03:24 PM
The Destroyer
49
Jul 9, 2010 12:03 PM
rx_86
Apr 1, 2010 04:49 PM
Jooleeus
Dec 22, 2009 06:47 PM
Unjockable
34
Mar 3, 2004 07:38 AM
