finding TDC by dist rotor and cam pully? for valve adj
Old 11-12-2002, 10:44 AM
smokin rubber's Avatar
Default finding TDC by dist rotor and cam pully? for valve adj
I have an aftermarket flywheel and so can no longer set the engine to tdc by it. How accurate to you have to be with tdc, If the rotor is pointed at the correct wire and the cam pully is aligned correctly is this enough?
Old 11-12-2002, 10:57 AM
Spade's Avatar
Default Re: finding TDC by dist rotor and cam pully? for valve adj (smokin rubber)
IT's actually a lot eaiser than that.....just rotate the enigne until there is no pressure on the rockers and you can slightly wiggle them.
The whole point in putting it at TDC is to get the gap between the cam and the rocker.
Old 11-12-2002, 11:12 AM
Desslok's Avatar
Default Re: finding TDC by dist rotor and cam pully? for valve adj (Spade)
An old trick I have used is this:
Pull off distributor cap and mark where the #1 plug goes on the distributor(chalk works good(or a scratch, whatever) pull the #1 spark plug and insert something long that can move freely (I use a long screwdriver) in and out of the spark plug hole. Rotate the motor with a ratchet on the crank bolt and when the ignition rotor gets towards the #1 mark watch the screwdriver, it will move up, pause for a second and then start to move back down, when it pauses, this is TDC for #1, it's then easy to find all the others.
There is an easier way, but it assumes your timing belt is on right and you have a stock cam gear installed correctly:
Get the rotor to #1 plug wire position, the up ^ on the cam gear will point up and then use a straight edge(ruler) to lign up the top of the head with the alignment marks on the cam gear.
Old 11-12-2002, 11:42 AM
thanks
PalmSpringsDelSol
01-21-2008 05:11 PM
lsracer27
03-18-2007 12:31 AM
mjrage
06-01-2004 10:33 PM
senpai
08-20-2003 07:08 PM
Brolli007
09-09-2002 06:27 AM
Quick Reply: finding TDC by dist rotor and cam pully? for valve adj
