F20B Problems
Old Nov 30, 2007 | 06:58 AM
FutureCivic's Avatar
Default F20B Problems
Hey Guys
Anyone had a problem where your doesnt rev up smoothly when on part throttle. It hesitates between 1000 - 3000 rpms, like there is something restricting it, after 3000rpm it goes up nicely all through vtec. I knw the F20B has the dual plenum intake mani like the gsr. Could this be sticking up causing no airflow on the bottom end?
Mods on the car are....
Short Ram Intake from Top Fuel
FGK Headers
FGK Exhaust
Bigger TB - not to sure of the size...it came with the car.
I suspect the ecu has been modded but i havent checked.
The engine was recently rebuilt tho.....might be a vacuum or mech prob??
Thanks
Old Nov 30, 2007 | 07:19 AM
r1ch1e's Avatar
Default Re: F20B Problems (FutureCivic)
I had that problem. My timing jumper 3 teeth on the cam side but this was on my b18b. Check you timing.
Old Nov 30, 2007 | 08:57 AM
King V's Avatar
If the engine was rebuilt, was the ignition timing set right?
Old Dec 6, 2007 | 07:38 AM
r1ch1e's Avatar
Default Re: F20B Problems (King V)
i did timing on a f20 b4 and it has 3 timing marks to line up. were those 3 marks lined up?
Old Dec 11, 2007 | 06:39 AM
Default Re: F20B Problems (r1ch1e)
Ok will check and get back to you guys. Thanks...
Old Aug 3, 2011 | 03:38 PM
VivaLaMikey's Avatar
Hey guys i know im diggin up old threads here but im having this same problem, seems like im also losing power.
I just wanna know would this just happen randomly like 1 day be sweet then eventually get worse over time?
I get the same issue rev's bog out at a certain point, my exhaust note changes, loss of power etc.
Old Aug 3, 2011 | 06:28 PM
exb18c1's Avatar
Originally Posted by FutureCivic
Hey Guys
FGK Headers
FGK Exhaust
Thanks
do you have a chance to check a vacum.that would give you few clues.
does the check engine light is on
wpgcivic
Jan 16, 2005 06:15 PM
fufu
Sep 19, 2004 04:21 PM
Jaydeep
Apr 28, 2004 07:15 PM
Dc5-Power
Jan 22, 2003 05:32 PM
thecorey
Dec 11, 2002 06:56 AM
