timing problem?
timing problem?
I put the car in first and hit the gas and the car slugs. It feels bogged down till the rpms rise up then it takes off. Then when I shift to second it does the same thing. sluggish then back to normal. I think its timing problem. So I check code but light just stays on. Guys what would be the problem.
Re: timing problem? (Jaydeep)
so you are throwing a check engine light? Its not giving you a code when you check it? Also if its your timing then check to make sure its all lined up.
I had the same problem a few days ago. I posted and I was told timing was off. Sure enough. Adjusted it and I am back to normal. Here's my post. Hope it helps.
https://honda-tech.com/zerothread?id=843212
prcivic91
04-03-2007 11:35 PM
