ES urethane bushing lube?
Old Aug 16, 2003 | 01:47 AM
chris@allmotor.net's Avatar
Default ES urethane bushing lube?
ok, so what do i need to lube these bushings with before i put them in so they dont squeek? and what bushings do i lube? right now im doing the lower control arms (front) and upper control arms (front).
Thanks in advance.
Old Aug 16, 2003 | 04:07 AM
J2turbo21's Avatar
Default Re: ES urethane bushing lube? (chris@allmotor.net)
I beleive the lube is for when you try to push them in.They also give the lube for the shifters and it makes it a breeze to push the busing through.
Old Aug 16, 2003 | 05:42 AM
Prelude Vtec 23's Avatar
Default Re: ES urethane bushing lube? (J2turbo21)
They help alot to push them in but the main reason is so they dont squeak. When I was installing mine I forgot to grease up the rear driver side and it was squeaking like hell. So I had to take it all apart again and grease them up.
Old Aug 16, 2003 | 02:56 PM
Default Re: ES urethane bushing lube? (Prelude Vtec 23)
ok, what grease is used then? that was what my main question was...heh..just regular all purpose grease? or is there some kinda grease that isnt damagint o bushings? im kinda in the dark
Old Aug 16, 2003 | 06:42 PM
still lookin for an answer
Old Aug 16, 2003 | 08:35 PM
pro1342's Avatar
The grease ES sends with the bushings is so-so, I used Super Hi-temp Urea Grease from Honda...part#08798-9002, it seems to work well.
Old Aug 17, 2003 | 11:18 AM
Default Re: (pro1342)
what about this silkolene Pro RG2 all purpose racing grease made by fuchs...i originally bought it for my little XR50R for the springs and stuff...can this be used?
on the back it says "synthetic racing grease" says heat resistant too.
Old Aug 17, 2003 | 01:23 PM
PhatOptimo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris@allmotor.net &raquo;</TD></TR><TR><TD CLASS="quote">still lookin for an answer </TD></TR></TABLE>
http://www.spohn.net/index.cfm...id=33
Old Aug 17, 2003 | 06:39 PM
Default Re: ES urethane bushing lube? (Quantum_CRX)
will my silkolene stuff work?
beanbag
Oct 6, 2007 05:00 PM
Loserkidwac
Jul 5, 2006 11:57 AM
Jdm93civic
Aug 24, 2003 10:47 AM
Rain_man
May 1, 2003 08:34 AM
SoulSurfer
Dec 10, 2002 10:45 AM
