engine problem
Old Aug 15, 2003 | 07:57 PM
prdtr15's Avatar
Default engine problem
my engine is idling at 2500 then dropping to 1000, and it keeps going back and forth, whast could the problem be?
Old Aug 15, 2003 | 10:41 PM
PHiZ's Avatar
Default Re: engine problem (prdtr15)
IACV? Idle air control valve?
Adjust the idle set screw? (it's a flat-head on top of the throttle body, before you ask)
-PHiZ
Old Aug 24, 2003 | 11:16 AM
prdtr15's Avatar
Default Re: engine problem (PHiZ)
That didnt work, anyone eles have anything?
Old Aug 24, 2003 | 03:03 PM
prdtr15's Avatar
I need help here, i really wanna get this fixed asap, but nothing has worked, so any ideas would be great
Old Aug 24, 2003 | 06:33 PM
SDT Project EF's Avatar
check for vaccum leak, maybe throttle position sensor?
Old Aug 24, 2003 | 06:36 PM
mmuller's Avatar
Mad Scientist
Default Re: engine problem (SDT Project EF)
check the fast idle thermo valve if you have one, take it out and shake it; if it rattles, then take it apart and screw the white plastic screw back
gutted-dx
Dec 18, 2005 09:08 PM
R. Mack
Jun 1, 2005 07:55 PM
CRX-SIR
Sep 20, 2004 06:00 PM
caLiH22A
Aug 24, 2004 08:05 PM
wolf3007
Mar 26, 2004 05:06 AM
